.obj Export: NURBS curves exported with reverse orientation #72326
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#72326
Operating system: Windows 10 Pro 64-bit
Graphics card: NVIDIA Geforce GTX 1080 Ti
Broken: v2.80
Worked: (unknown)
When exporting a NURBS curve to an .obj file, the vertices of the curve are listed in the "forward" order; but the curve references them in the reverse order. This yields the curve with its orientation reversed.
To reproduce the error:
Blender file:
OBJ file:
The vertices in the file are listed in the order in which they appear in the curve.
The obj definition "curv 0.0 1.0 -1 -2 -3 -4" uses negative indexing, which counts the vertices starting from the bottom up, yielding the reverse orientation.
This is explained in the .obj specification start from line 652.
Added subscriber: @chafner
Added subscriber: @EitanSomething
Is this still an issue with 2.83?
Added subscriber: @ankitm
Both relative and absolute indices are supported in OBJ for all types. Blender just happens to use it for Curves. The orientation is dependent on the importer and the axis transform the importer does.
Did you try importing the curve back into Blender to see if it was flipped?
Is it problematic for other apps ? If so, in the newer OBJ writer, we can write it in positive indices just like other objects as it's easy to change.
