Floating point exception (crash) when switching to Edit mode #72387
8 Participants
Reference: blender/blender#72387
Operating system: Linux-5.3.0-23-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: AMD BONAIRE (DRM 2.50.0, 5.3.0-23-generic, LLVM 9.0.1) X.Org 4.5 (Core Profile) Mesa 20.0.0-devel (git-8259c97 2019-12-07 eoan-oibaf-ppa)
Broken: version: 2.82 (sub 5), branch: master, commit date: 2019-12-11 18:53, hash:
b03066f7ee
Blender starts normally, the minute I try to switch to edit mode, be it via hotkeys, calling the operator from the search menu or just switching from the mode list, it crashes. Other modes work just fine.
I've tried with
--factory-startup
but the results are the same.I'm starting to think that perhaps it's something I might have done on my end with Ubuntu? Could that be possible?
Clearly something's not working in blender, but I can run 2.82, 2.81a and 2.81 just fine from Windows, and until fairly recently, (before it started crashing on #72258) I was running 2.81 just fine in Linux too.
Enter editmode
I'm including system info and my config files.
system-info.txt
Edit: I removed the config files and keymap related stuff to avoid confusion. The debug-gpu log is in the comments.
Added subscriber: @karmaral
#72885 was marked as duplicate of this issue
Added subscriber: @mano-wii
Is the custom keymap related to cash?
To find out, try after loading Factory Settings. (
File -> Defaults -> Load Factory Settings
)If it is not related, this information will only hinder.
Also try to run
blender_debug-gpu.cmd
that is included in the download. After Blender closes, the logs will be in a text file which can be attached here.It seems it isn't. I only included it because both errors started happening simultaneously. I will edit the post appropiately then.
What download? I don't have such file, but it should be the same as
-d --debug-gpu
, right?gpu-dump.txtAfter peeking the logs I bit, I tried switching to editmode with overlays disabled, and this time it didn't crash. As soon as I turn them back on while in editmode, it crashes. I suppose that narrows it down a bit.
Added subscriber: @AlanT
I've been having similar problems and I think there are enough similarities for me to mention them here.
I've fixed (side stepped?) the crash by switching from radeon drivers to amdgpu drivers. Switching back to radeon drivers causes blender to crash again.
I'm using Arch Linux and used these links for information on switching drivers:
R9 390 (Hawaii) series poor performance and/or instability
Enable Southern Islands (SI) and Sea Islands (CIK) support
I hope this helps you with your crash.
system-info.txt dump.txt
The dump file does not indicate much.
What is displayed if the option is just
--debug
?My original dump file was when running blender from the command line where it crashes straight away.
Dump file from the command line with just --debug:
cmd --debug dump.txt
Running debug in Qt Creator where the crash happens when entering edit mode:
QtCreator dump.txt
This is a driver problem.
In fact it seems to be a problem deep inside
glFlush()
.It would take a lot of trial and error outside the OpenGL API to understand what in blender results in this problem.
But this requires a developer with knowledge of this subject and the same setup available.
This can be hard to achieve.
Added subscriber: @georgK
Operating system: Linux-5.4.6-2-MANJARO-x86_64-with-glibc2.29 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.4.6-2-MANJARO, LLVM 9.0.0) X.Org 4.5 (Core Profile) Mesa 19.3.1
Broken: version: 2.82 (sub 4), branch: master (modified), commit date: 2019-12-10 16:09, hash:
4fa774b533
Worked: the same version worked before manjaro update
Seems like I am also affected:
After the latest manjaro update: [Stable Update] 2019-12-29 that brought mesa up to v 19.3.1-1, the new Blender 17:2.81.a-3 version does not work at all, it crashes at startup - the old version worked without problems. My own build is starting, but crashes with "Floating point exception (core dumped)" when switching to Material preview or Eevee rendered preview - and, like Al reported, when entering Edit mode.
It may be a coincidence, but so far it seems that older AMD gpus are affected (Verde from early 2012, Bonaire early 2013, Hawaii late 2013).
Unfortunately, there seems to be no core dump neither in /tmp nor in the folder that I configured for "Temporary Files".
Now I can't work with Blender at all anymore, so this is really important to me, please fix it.
Added subscriber: @seacrow
Operating System: Manjaro Linux
KDE Plasma Version: 5.17.4
KDE Frameworks Version: 5.65.0
Qt Version: 5.14.0
Kernel Version: 5.4.6-2-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5-4590 CPU @ 3.30GHz
Memory: 7.7 GiB of RAM
I am having same problem as Georg K.
"Floating point exception (core dumped)" at startup
nor is there anything in tmp to help
First post here so forgive me if I am not following usual protocol.
Thanks
Added subscriber: @Richard-Kubusch
@seacrow:
Guess you are one of the lucky owners of older AMD graphics as well?
I bypassed the problem by downgrading mesa. Also Blender 2.79 https://download.blender.org/release/Blender2.79/latest/ is still working (but segfaults opening 2.82 projects). Those are no solutions in the longer term, but at least we can continue our projects.
@georgK
Thanks for this.
I'll downgrade mesa.
I was just getting used to Blender 2.82!!
Guess I need to swap out my graphics card if I can scavenge one from my son!
Added subscribers: @Kronstoeckel, @StephenSwaney
Well. I'm not sure what happened, but a bunch of things got updated via the Software Updater and now everything seems to be working. No crash so far, and the older versions that were previously broken are back.
Here's the list of things. Obviously drivers, but I can't discern much.
update log.txt
I'm using 2.82
3a35301fd1
and no crash when entering editmode so far.Here's the system info just in case.
system-info.txt
Since my latest system update blender is working again.
Sounds like everything is working after system software updates.
Closing
On manjaro stable, the latest Mesa is still 19.3.1-1 from 18.Dec 2019.
What version of Mesa solved it?
I updated my Arch Linux today and got 19.3.2-1
Thank you, guess I will have to wait two weeks until it lands on Manjaro, too.
edit:
Solved on Manjaro as well as of 16.1.2020 (upgraded to Mesa 19.3.2-2)
