Brush Size not accurate on hiDPI retina screen #72404
8 Participants
Reference: blender/blender#72404
Operating system: Darwin-19.0.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 560X OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.2.24
Broken: version: 2.82 (sub 4), branch: master, commit date: 2019-12-10 23:56, hash:
63d521432e
When setting the Brush Size in Particle Edit mode it displays one size (first pic) and after you confirm it shows it way bigger. The actual area of the brush that works is the right one though, the one you chose before confirming.
Added subscriber: @GabrielMoro
Seems to work for me. Please provide a simple .blend file that allows me to reproduce the issue.
This is not specific to a project... There's a way to reproduce this in the default file in 50s, I recorded it.
You can see the brush behaviour is very inconsistent in the Particle Edit.
ScreenFlow.mp4
Added subscriber: @mano-wii
I cannot reproduce this with either the latest stable or current development versions of Blender.
Is this a problem with your keymap settings?
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Tested on todays build and now the problem is only that the Brush size isn't accurate once you "release" when resizing.
Everything on the brush radius is moving but it isn't on the size I set it to be (when using the F shortcut).
ScreenFlow.mp4
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
As hard as I try, I can't reproduce the problem:
Added subscriber: @lichtwerk
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Also cannot reproduce this here.
Just to be totally sure we are all on the same page: could you share your .blend?
Sure! There you go: untitled.blend
I loaded the factory settings as asked for the test I posted.
Maybe it's Mac related? It often is when I report bugs...
Interesting that you mention that the problem happens when you
release
.But by default the brush is applied when you
press
the mouse button.This makes me suspect that your keymap is different.
Just the wrong word used... You can see me struggling with the Tab shortcut because of the "Load Factory Settings" on the video.
The thing I did was:
F > Slide to scale > F again to apply (what I meant by release).
Added subscriber: @iss
I can not press F to apply
I have to do F > Slide to scale > Click to apply
Will close this report because of no new info, that would help us to reproduce the issue.
I gave all the info I had... you can see in the video how it behaves. It’s probably Mac related so a Mac developer could probably reproduce.
Changed status from 'Archived' to: 'Needs Developer To Reproduce'
I can reopen this, but there are numerous issues with macOS currently, because openGL is no longer supported on that platform. Therefore we can not guarantee fix even if issue could be reproduced.
Added subscriber: @jenkm
It depends on the pixel density of a screen.
If you "Open in Low Resolution", then all will work fine.
When you adjust "Brush Size" (F) you see a circle with a radius without taking into account the hiDPI.
Brush Size display not accurate in Particle Editto Brush Size not accurate on hiDPI retina screen@jenkm Thanks for more info.
Added subscriber: @brecht
@brecht here's the patch for that.
This issue was referenced by
27fa33c143
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
