[Mantaflow] Wrong fluid mesh position #72644
11 Participants
Reference: blender/blender#72644
Graphics card: AMD Radeon HD 7560D ATI Technologies Inc. 4.5.13399 Core Profile Context 15.200.1062.1004
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-20 00:09, hash:
c3782ebf44
The liquid mesh has an incorrect position.
If you bake the particles in this scene and then bake the mesh, you can see this error:
test_02.zip
Added subscriber: @Pavel_Blend
#76967 was marked as duplicate of this issue
#76076 was marked as duplicate of this issue
#73703 was marked as duplicate of this issue
Added subscriber: @juang3d
This is happening because the domain pivot is not in the correct place.
I don't remember if it has to be in the geometry center or in the world center, but if you center the pivot and rebake the sim, everything should be in the correct place.
Having mantaflow to counteract a wrongly placed pivot is more like an improvement (a very welcome one, and possibly an easy one) than a bug IMHO :)
Added subscriber: @Firepal
Added subscribers: @sebbas, @mano-wii
If this worked in the previous fluid code, this could be considered a regression.
But it may also be a known limitation (in this case it would be nice to be described in the manual ).
@sebbas, what do you think, bug or limitation?
I tested on the system from previous versions (without mantaflow), and the fluid position corresponded to the position of the objects used, even with the origin of the domain not in the center of it.
So it's a regression.
Added subscriber: @PGT2
I had the problem as well with latest builds, i found a manual fix that i think would be easy to code.
Before baking set the domain origin to the world center.
Then in edit mode adjust size and position of where you want your domain to be.
After the baking is the done set the domain origin to center of volume (in later frames where it still a a cube, ea use a past frame or frame -1).
(One might use empties for those 2 positions if one needs to bake more then once).
Of course it should be solved in code, but the displacement is exactly solved with this workaround and might be coded as well
Added subscriber: @NahuelBelich
Added subscribers: @ScottVanKirk, @ankitm
#76312 (Liquid simulation Particle/Mesh vanishes - Only Domain is rendered)
gets worse after render. Confirmed separately.
Added subscriber: @Vyach
Added subscriber: @CrossmindStudio
to get the fluid mesh at right position, the original has to in the exact center of the domain object.
Else the mesh is offset by a margin of origin offset( from center).
This has been fixed by
b44101950d
