Bolt Factory: Missing Data after Change Bolt. #72654
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#72654
Operating system: Win
Graphics card: hd7850
Broken:
Probably for a while...
Worked: Before changes.
Unable to create new bolt after change bolt then bolt deletion.
Add a bolt.
Click in the 3d view to remove the operator menu.
Right click to access the specials menu "Change Bolt" and press it.
Change settings in the operator panel.
Delete the bolt.
Using the Add Menu, try to add another bolt.
Error:
@cwolf3d
Hi, can you please fix this? I think you may find it affects all addons that use the "Change it". I've noticed issue with Geodesic Domes but not tested all the others yet.
Thanks.
Added subscribers: @cwolf3d, @BrendonMurphy
Setting Priority.
Added subscriber: @VanessaE
Copied over from blender/blender#72651 by request:
If I add a bolt, then select it and change it [by using "Change Bolt" in the object context menu], and then immediately add a second bolt (by doing
Add -> Mesh -> Bolt
again), this second bolt overwrites the first one, as though I were still trying to change that one. It keeps doing this no matter how many times I try... unless: if I add some other mesh such as a cube, the next add-bolt action indeed creates a new bolt.This issue was referenced by
2f4c557df0
Bug fixed: https://developer.blender.org/rBA2f4c557df001572041f90d36931abbd1fead8b4a
Later I will fix it in the other add-ons.
thanks!
