Sculpt Box Hide Undo+Redo cause artifacts when using smooth shading #72721
Closed
opened 2019-12-27 06:33:22 +01:00 by Pasang Bomjan · 16 comments
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-26 19:15, hash: d35a319687
After using box hide tool and doing Undo + Redo, it creates visible artifacts...
  1. Open the attached blend file and in sculpt mode, use the box hide tool to hide a part of the mesh.
  2. Then Undo the last step and then Redo it.
Box Hide Undo Redo Bug.mp4
I get that issue in both of my machines. And I also checked by exporting and importing as an OBJ but always get the same case.
Here's the exact file.
Box Hide Undo Redo Bug.blend
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66 **Blender Version** Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-26 19:15, hash: `d35a319687` Worked: (optional) **Short description of error** After using box hide tool and doing Undo + Redo, it creates visible artifacts... **Exact steps for others to reproduce the error** 1. Open the attached blend file and in sculpt mode, use the box hide tool to hide a part of the mesh. 2. Then Undo the last step and then Redo it. [Box Hide Undo Redo Bug.mp4](https://archive.blender.org/developer/F8245647/Box_Hide_Undo_Redo_Bug.mp4) I get that issue in both of my machines. And I also checked by exporting and importing as an OBJ but always get the same case. Here's the exact file. [Box Hide Undo Redo Bug.blend](https://archive.blender.org/developer/F8245649/Box_Hide_Undo_Redo_Bug.blend)
Author
Added subscriber: @Pasang
#73367 was marked as duplicate of this issue
Added subscriber: @ronsn
@Pasang Is that video you uploaded playing in your browser? Here on Linux in Chromium and Firefox it is not playable.
Author
@ronsn It should play in Chrome. But it sometimes doesn't play in Edge. Can you try downloading the video?
Member
Added subscriber: @lichtwerk
Member
Member
I can confirm, looks like this here:
I can confirm, looks like this here: ![image.png](https://archive.blender.org/developer/F8248059/image.png)
@Pasang Downloading the video worked. I can confirm the issue too, but I couldn't reproduce it on other meshes with much higher poly count. Is this the only mesh, where that issue occurred?
Looks like art somehow
@Pasang Downloading the video worked. I can confirm the issue too, but I couldn't reproduce it on other meshes with much higher poly count. Is this the only mesh, where that issue occurred? Looks like art somehow ![Bildschirmfoto vom 2019-12-28 15-08-55.png](https://archive.blender.org/developer/F8248203/Bildschirmfoto_vom_2019-12-28_15-08-55.png)
Author
@ronsn Curiously yes. It doesn't happen in any other meshes. Maybe something's wrong with it's mesh data. I tried with OBJ and FBX export-import but same issue.
@Pasang The Issue does not occur in Blender 2.79 but in Blender 2.80, so somewhere in between those versions there must be the commit which is responsible for that issue. Bad news is, I cannot compile Blender 2.79 on this machine to find the exact commit.
What kind of worked was to remesh the frog and maybe that might be a solution for you for now.
@Pasang The Issue does not occur in Blender 2.79 but in Blender 2.80, so somewhere in between those versions there must be the commit which is responsible for that issue. Bad news is, I cannot compile Blender 2.79 on this machine to find the exact commit. What kind of worked was to remesh the frog and maybe that might be a solution for you for now.
Pablo Dobarro changed title from Sculpt Box Hide Undo+Redo cause artifacts to Sculpt Box Hide Undo+Redo cause artifacts when using smooth shading 2020-01-09 20:11:39 +01:00
Member
Added subscriber: @PabloDobarro
Member
After investigating, the bug is not related to that particular mesh, It can also be reproduced by subdividing any other mesh to a point it creates multiple nodes and setting it to smooth shading.
If this is not fixed before, we may revisit this again after reviewing the design and merging the new visibility system in D6070, because that could also fix this issue.
After investigating, the bug is not related to that particular mesh, It can also be reproduced by subdividing any other mesh to a point it creates multiple nodes and setting it to smooth shading. If this is not fixed before, we may revisit this again after reviewing the design and merging the new visibility system in [D6070](https://archive.blender.org/developer/D6070), because that could also fix this issue.
Added subscriber: @Facu
This issue was referenced by f4411b58ad
This issue was referenced by f4411b58ade1d4d0921243756ecd3499e8d11cd2
Member
Pablo Dobarro self-assigned this 2020-02-25 19:02:31 +01:00
6 Participants
Reference: blender/blender#72721
