Gizmos blink when selecting with right mouse button #72736
5 Participants
Reference: blender/blender#72736
Windows 10 64 Bits.
Graphics card GeForce GTX 1080 Ti.
Broken: version: 2.82.6, branch: master, commit date: 2019-12-27 12:51, hash:
d2dc4f8411
Worked: 2.79b, 2.80 & 2.81.
Whenever you select or extend select the gizmos do a quick blink.
{F8246599 size = full}
Added subscriber: @CobraA
#73189 was marked as duplicate of this issue
Added subscribers: @ideasman42, @JacquesLucke
Steps to reproduce:
Whenever, the mouse button is down, the gizmo disappears.
@ideasman42, is this a bug, limitation or working as intended?
This is working as intended, without this - the gizmo flashes on and off when tweaking the mesh.
This video shows what happens when tweaking vertices with this behavior disabled.
#72736.ogv
This is about selection without tweaking.
In versions of 2.80 & 2.81 this worked correctly so something has changed since then.
{F8279621 size = full}
Added subscriber: @WilliamReynish
The current behavior is needed to support gizmo and tool interaction, so gizmos don't "catch" a tools interaction by appearing under an event which was intended for a tool #66304 (Tools, Selection & Gizmo design).
This video shows the problem (notice the second click-drag doesn't tweak).
out.ogv
If the flickering issue is considered a bad enough problem, we could prevent the flickering while keeping this behavior.
Personally I don't find this so bad, and there is even added flickering if this behavior is reverted (as mentioned in my previous video).
So I would like to get feedback from the UI team on this one.
Marking as a design task.
Gizmos blink whenever you select.to Gizmos blink when selecting with right mouse buttonChanged status from 'Archived' to: 'Confirmed'
flickering is bad enough if you have to (shift) select thousands of verts,edges and faces on a daily basis, this seems like adding more complexity when there is already a tweak tool that does the job.
This is a somewhat annoying known issue if you use a combination of features currently. With left click select this issue doesn't appear unless you use Tweak drag mode, in which gizmos don't make too much sense anyway.
Improving Tweak Drag for all tools is something that would be nice to do. We could have nice pre-selection highlighting, and cursors that help communicate what will happen when you drag on an item. Making this work well is not likely to be a trivial fix, so marking this as Known Issue for now.
