Setting alpha channel in compositor affects RGB channels (white artifacts) #72740
Reference: blender/blender#72740
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
Worked: probably never
When combining RGB channels with alpha channels in the compositor, this generates white artifacts on the output RGB channels.
Use some RGB image and either use the set alpha, separate rgba and combine rgba setup (as shown in the image) and connect this to the composite, viewer or some file output node for the viewer or compositor output one can also use the dedicated alpha output, all methods result in white artifacts on the RGB channels, this causes problems when one wants to use the compositor for channel packing involving the alpha channel (combining four greyscale maps into a single RGBA image).
alpha_fail_on_rgb.blend
(toggle the backdrop option in the compositor to trigger the processing)
Another example that uses actual render layers:
rendered_alpha_artifacts.blend
Added subscriber: @bestdani
I assume the issue here is that you use an alpha mode for the image that is not correct for your use case. I cannot check that because you did not upload the .blend file. Please always provide a simple test file with the images packed into it for reports like this.
The white border are usually related to premultiplied alpha afaik.
I have just added a blend file with even some little bit simpler (and cc0) images.
It also reminds me of premultiplied alpha, but in this case it happens on the output images and there's no option to change the alpha behavior at all for this afaik.
I'm also not sure if this is intended or not, so if this is an actual bug or not. At least I was not expecting that setting an alpha channel like that would affect the RGB channels of an image and I guess in many use cases where one wants to pack for example roughness together with a rendered / baked albedo or normal into a single RGBA image this is probably not what is wanted and expected to happen.
Added subscriber: @Jeroen-Bakker
Unfortunately, I also don't know that. @Jeroen-Bakker might be able to answer that color management question for the compositor.
Added subscriber: @iss
looks like quite different issue, but similar in result #69106 (White outline around alpha in texture paint (when using multiple layers))
Added subscriber: @brecht
The Blender compositor uses premultiplied / associated alpha. That means if you want to apply an alpha mask to an image, that must affect not only A, but also be multiplied into the R, G, B channels.
Rather than manually manipulating the channels like this, it's easier to use for example an Alpha Over node to to mix between a given image and a fully transparent RGBA color.
