Memory increase on duplicate and delete objects without limit #72853
5 Participants
Reference: blender/blender#72853
Operating system: Linux-5.3.0-24-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GT 630M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.129
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
When I have a script that runs multiple times duplicate an object increases the memory that I consider normal, but then that same script deletes the object from the scene and its orphan meshes too but the memory is not released, every time I run the script again the memory continues to increase without limit.
Option 1:
Copy script in python interpreter inside blender and run it again a few times or
Option 2:
Use the addon verión of script and press buton few times.
With any of those the problem can be exprienced and seen
Script version:
https://pastebin.com/1f8QzY8z
Addon version:
https://pastebin.com/8d98PQwC
Added subscriber: @zebus3dream
Added subscriber: @juang3d
This is the script, in case it's lost from pastebin :)
I think this is rather important because we tend to use different scrpits to scatter objects, or to procedurally modify a scene, and it feels like a big memory leak.
Added subscriber: @antoniov
I have run the script in Windows using the last master code and I didn't see any memory leak running in debug mode.
Here the VS2019 memory chart:
Doesn't every time you run it increase your memory usage?
No memory leaks, I run 4 times and the memory in VS is the same....but in the bottom bar the Blender memory stat increases.
I have run in debug mode and this doesn't show any leak message and the VS memory chart keeps flat.
Then may there be a problem with the stats and not with the memory?
Not sure. I don't know how the memory stats work.
Added subscriber: @Sergey
Stats in the status bar will show amount of memory which Blender requested from the system. The system monitor (and the one in VS) will show memory which was allocated to Blender by the system.
Now, the system memory allocation might allocate more memory than is required at a specific moment and hence make subsequent allocation to happen faster.
What you can do to help investigating the issue is to run Blender with
--debug-memory
command line argument and watch output of "Memory Statistics" operator.@Sergey I have done what you said and I only see a difference:
Test 1:
Test 3:
Looking more in detail, this memory is allocated by Undo system (
writedata_do_write()
), so maybe is only the undo information.Added subscriber: @mano-wii
Can you see if the same happens if you reduce the amount of
undo steps
?Preferences -> System -> Undo Steps
@mano-wii You are right. If you set the undo to
0
, the memory increases in a very slow rate, .Changed status from 'Needs User Info' to: 'Archived'
@zebus3dream, thanks for the report.
This is not a bug, it's how the memory is used by the Undo system.
Your script calls
bpy.ops
within a loop, and for each call, an undo step is added.
