When changing the width of frame, it also changes frame location. #72904
Reference: blender/blender#72904
If you create frame and set it into (0,0) location. Then grab right side of the frame node and make frames width bigger. Now using python read the frame
location again and it is not (0,0) anymore.
Added subscriber: @Kalle-SamuliRiihikoski
https://blenderartists.org/t/how-frame-location-is-calculated/1199582/3
Frame location with python has issues.to When changing the width of frame, it also changes frame location.I found out that if I delete this part from node_edit.c line 983
deleting this part of code gives better result when you read frame location . It still dosen't give correct values thou. It would be nice know why this code part is there because in my tests frame node works without this code part just okey.
Added subscribers: @JacquesLucke, @brecht, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Yeah, this is a bit strange (since - from the python visible side - you can run into 2 frames having the exact same width, height & location, nevertheless they dont appear at the same spot).
This is caused by the node also having an offset [used in C, transform/drawing code etc], but this is not exposed to python, so no access there...
The offset was implemented in
53b01d9002
.In theory, I think frame nodes could even live without this (and only rely on location, width & height), but this would require a bit of refactor.
So maybe a solution is to just expose this offset to python?
However, this doesnt really look like a bug, it is more of an improvement to a [incomplete/annoying] implementation.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this might not be considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Hesitating to close though, this might be added as TODO to #66307 (Nodes & Physics Module), will let @JacquesLucke or @brecht decide...
This would be import for me because I coding NodeCustomBuilder addon where nodetree is transferred into json file. I have had some difficult times to save frames exact location (including nodes that are inside of the frame) locations. I would be willing to work with issues if get some guidance what would be the best fix for this annoying issue.
This for me sounds the most logical way but I really don't everything what going on under the hood.
Added subscriber: @ideasman42
Setting as TODO since this works as intended.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Added subscriber: @RayMairlot
