EEVEE: Add support for extracting alpha channels from a color #72941
Reference: blender/blender#72941
I mistakenly filed a bug report --> #72856 EEVEE transparency problem with mtpaint PNG
I didn't fully understand the bug and attached a blender file that didn't show the bug properly.
Packing the image file with blender command 'Pack' makes the image
opaque so it is worthless to include a blender document. I will
include a mtpaint PNG image instead and you can load it into
blender 2.81 yourself and see how it renders in EEVEE versus cycles.
I noticed that your forum converts the image to opaque if I try to attach to this post
so I'll use a shareable link that preserves the transparency:
https://drive.google.com/open?id=1TjfSjzabYEmVHXTODPFymGVNwuL02SnJ
Here is how I created the mtpaint image to reproduce the problem...
EEVEE rendering doesn't respect the transparent region.
Cycles rendering does respect the transparent region.
Not a high priorty.
Added subscriber: @don570
mtpaint transparency problem in EEVEE renderto EEVEE: Add support for extracting alpha channels from a colorAdded subscriber: @Jeroen-Bakker
Hi @don570
I have to file this as a To Do. EEVEE currently does not support alpha extraction from a color. This can be added, but that is adding a new feature, and not a bug.
I see two ways how to implement this.
I expect that the shader compilation would be preferred (performance & memory).
Added subscriber: @Foaly
I disagree, this is a bug.
The problem is rather that ImBuf does not correctly read the tRNS chunk for RGB images (although it already does for grayscale and palette images).
Solving this should be as easy as adding another
png_set_expand
call.It has nothing to do with EEVEE, the same problem occurs in all other areas of Blender.
It's just a coincidence that Cycles implemented its image loading separately.
As for implementing this with a separate shader:
Please don't: It's not worth the time and added complexity, considering that such files are rare.
The developer of mtpaint (wjaguar) https://github.com/wjaguar/mtPaint
contacted me, and here is what he wrote...
Hey guys, I don't disagree that it is an issue. According to the rules of the bug-tracker we decided upon the next rules https://code.blender.org/2019/12/tracker-curfew/
code was not intended to work as expected by the reporters. Issue is in ImBuf what needs a large overhaul as it has many issues. We can hack something, but that would lead to more maintenance. Doing it once good will reduce maintenance, but will need a new design. Hence I filed it as a todo.
