Program hangs indefinitely when attempting to access any property of "link_loops" (BMElemSeq) #72946
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#72946
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
blender/blender@f1aa4d18d4
Program hangs indefinitely when attempting to get length of, iterate, or access any element in "link_loops" property of BMElemSeq, of bmesh created from object in blend file:
crash.7z
load blend file
Switch to Scripting View
Run the following python script code:
Added subscriber: @pyro789x
Program hangs indefinitely when attempting to get list of, or iterate, "link_loops" property of BMElemSeqto Program hangs indefinitely when attempting to access any property of "link_loops" (BMElemSeq)Added subscriber: @Stan_Pancakes
There's something very wrong with the geometry in that particular mesh. For example, there are edgeless faces (0 and 5). Attempting to cut an edge there manually (between verts 0 and 3) will also result in this freeze. Deleting both faces and trying to fill the hole with alt+f fills with "edgeless" faces again.
How was this mesh created? Is that an import? If this was created solely with Blender's tools, it'd be nice to find out how, exactly, such errors became even possible.
To "fix" the geometry you can run, in Python console, this (while being in object mode):
Not sure if you consider it "with Blender's tools", but it was created with the "from_pydata()" function
Here's the raw input:
make_bad_mesh.py
looks like throwing a blendMesh.validate() after blendMesh.from_pydata() does fix the issue. I wonder if from_pydata() should include an internal call to validate()?
Added subscriber: @lichtwerk
Thx for the report, but this does not look like a bug to me.
(I havent checked in detail -- debugging external scripts for the exact misusage is out of scope of the bugtracker in this case, sorry)
But there is already a fat warning in the docs regarding this:
https://docs.blender.org/api/master/bpy.types.Mesh.html#bpy.types.Mesh.from_pydata
Closing as this is working as intended...
I wouldn't really classify it as a "script", the provided input is just providing a set of hardcoded vertices and faces. I'm also not seeing any of the issues you mention in the face list (out-of-range-indices, edges that contain the same index multiple times, or 2-sided faces, as each face is a simple triangle)
