Animation Render #73039
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#73039
https://github.com/thebadking/animationrender/
animation render Blender addon.zip
Blender Animation Render Process that bypasses GUI to avoid crashes
Tested on macOS, Windows and Linux. (from blender 2.80 to 2.83)
Animation render is an addon for blender, it renders by python script bypassing the GUI, avoiding all the crashes that are GUI related while rendering. It works for cycles and eevee. It allows you to render an interval of frames grabing the details from context like first frame and last frame, output path and all the details required for rendering, it adds some buttons on the Output menu like:
Notifications include how many frames are to be rendered, current frame, percentage of completion and time estimate for completion
If you are having problems rendering even one frame you can set the first and the last frame to be the one you need rendered.
Disabling the Notification check will enable output to console.
Installing the addon on macOS should be done manually as the decompression method from blender destroys a binary necessary for notification. you can install the addon like this: uncompress both folders ( animationrender and modules ) place them on: /Users/"YOUR USERNAME"/Library/Application Support/Blender/"YOUR BLENDER VERSION"/scripts/addons/
Restart blender after activation module or notifications will not work until restart
Added subscriber: @TheBadKing
there is a bug while importing on macOS that forces the installation of the module "pync" to be manual since the binary terminal-notifier and blender which is a modified version of the terminal notifier so it has the correct name and icon for the notification.
this binary gets damaged and it will not work if installed though the Blender menu for addons.
I dont know if the binary is getting dammaged when importing on Windows or Linux since the module is only used on macOS and therefore not used on the other systems.
/Users/"USERNAME"/Library/Application Support/Blender/BLENDER VERSION/scripts/addons/modules/pync/vendor/terminal-notifier-2.0.0
Added subscriber: @iss
If you want to "promote" your addon please do it on our community sites like https:*devtalk.blender.org or https:*blender.community/c/today/
Have you read about the import bug?
This is to fix the import bug, not to promote the addon
@TheBadKing To report a bug in way that is useful you have to follow instructions that are on the page you use to file a report. Otherwise the report may be dismissed. Especially during times, when the number of reports to review is high.
We are thankful for every helping hand, but all contributions have to go through propper channels - to comply with goals, that are agreed on by maintainers and code review to ensure quality of contributions.
You can learn more here https://wiki.blender.org/wiki/Process
