Cycles > Volume > Alpha Channel #73152
5 Participants
Reference: blender/blender#73152
Operating system: Darwin-19.0.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel HD Graphics 4000 OpenGL Engine Intel Inc. 4.1 INTEL-14.2.16
Broken: version: 2.82 (sub 6), branch: master, commit date: 2020-01-14 23:08, hash:
3edd8d5b07
Transparency of scene is determinated by objects using non-volumetric material only.
Example use Cube with Visibility > Holdout to rise problem more visible.
Sorry, probably a bit confusing.
Solid Mode
Render Viewport Mode is OK
Render (F12) results with ERROR - spheres are rendered, but object itself is ignored for alpha channel
Render viewed as Color (without alpha)
test_Edge.blend
Note: spheres (volumetric) are not calculated also for ID Mask or Cryptomatte as well
Added subscriber: @FilipMond
Cycles > Volumetric > Alpha Channelto Cycles > Volume > Alpha ChannelAdded subscribers: @brecht, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Using a proper Volume Shader (Principled Volume / Volume Scatter) instead of emission directly will give proper alpha (but also adds to rendertime of course):
(Also shouldnt Emission be mixed with transparent if used at all?)
test_Edge_corrected.blend
However I think it was possible to use an Emission shader with Transparent and get alpha when saving to EXR (but honestly cannot get that to work atm)
Correction: this looks like it is expected behavior
In any case, there was also the issue with seeing this correctly in blenders Image Editor, see e.g. #42755 (Volumes do not appear when transparent film is enabled) and the mother of the Image Editor Issue #52680 (Alpha difference Viewport/F12 )
However part II: this now also seems to work now (I can see the alpha from the volumes in the Image Editor now with my file)... bit confused, will get a coffee :)
Added subscriber: @troy_s
Viewer is broken. Has been for nearly two decades.
Only associated alpha can encode the values, and the viewer pipeline breaks the association.
Just to be clear, it would be useful to add a composite against a coloured background to show that the alpha is being encoded properly.
This is a known bug though, due to broken alpha handling throughout Blender.
Due to TIFF and other proper file encodings being mishandled, the only way to encode this image is in an EXR if you seek to save this to disk.
Closed as duplicate of #52680
There is indeed a bug in the viewer, but the alpha channel contents is as designed.
Added subscriber: @Christian-Fritz
Wait, so having density at 0 and emission at != 0 or only connecting emission shader to volume renders correctly from the looks of it but has alpha = 0 AND this is designed to be like that? ALPHA = DENSITY? I really do hope this is a joke...
Alpha is, and always has been, degree of occlusion of the resulting spatial sample. It’s a rasterized representation of geometry. Emission without occlusion is extremely common.
