[Mantaflow] Particles not generated on Plane object #73161
6 Participants
Reference: blender/blender#73161
Operating system: W10
Graphics card: nVidia 970
Broken: blender 2.82
3edd8d5b07
windows64Short description of error
Open the attached blend file and hit Bake, you should see that particles don't get generated.
When you rotate Plane object either around X or Y axis a bit(or in Edit mode) and rebake, particles get generated. Rotating around only Z axis doesn't fix the problem.
Seems like if plane's dimension in one of the axis is 0 it doesn't work.
test01.blend
Added subscriber: @MiroHorvath
Added subscriber: @mano-wii
At first I thought the problem is that the inflow is an unclosed mesh.
But even enabling
Is Planar
, I can't make the simulation work.Added subscriber: @zeauro
There is a Surface Thickness setting under Flow Source Subpanel.
It is set to zero by default for Quick Liquid set-up. That is what you want when you use a closed mesh as a liquid volume.
But if you want to use a plane as an Inflow, you have to give a little thickness.
A value of 0.00001 is sufficient. In fact, it does not matter how small it is.
You just have to set a Surface Thickness higher than zero.
Thanks for the hint @zeauro, but still it's a weird user experience that I have to set non-zero Surface Thickness when plane has no rotation, but once Plane is rotated(either X or Y axis) it works even without non-zero Surface Thickness.
Added subscriber: @Lazza
I could be incorrect but... I've tried to understand what mantaflow does and it seems to "spawn" particles from a Volume. It refresh every steps and check if there's more space to put particles in. Since the plane has no Volume there are not cells to spawn particles. I think that all that problem will be cleared with a nice written documentation. It's not easy to guess what a software does only from the control panel.
By the way the surface thinkness it's been replaces with another parameter. Now it works. With a sufficient value (depending on resolution) it creates enough "virtual" space on the surface and mantaflow treat it as a Volume instead of a planar surface.
These are only MY consideration so don't take them as the pure truth. Just try it yourself
Added subscriber: @Walles
Added subscriber: @sebbas
The issue with surface thickness and planes has been resolved in
cda81d5a4d
(#73866 had the same issue).Closing since, in my view, this is no longer an issue.
