Immediate crash during cycles render directly after auto-save aborted with scene containing large texture #73230
Reference: blender/blender#73230
Operating system: Windows-10-10.0.17134-SP0 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: 2.82 (sub 6), branch: master, commit date: 2020-01-06 20:54, hash:
3a35301fd1
blender crashes with large 47mb jpg 27000 x 27000 image. Happens with both gpu and cpu rendering (so not vram related)
load a big image into a material, apply to object and render. Can't provide image as it's nda, but the image uncompresses to 2.2 GB, total vram usage when rendering on GPU was 2.4 GB as the scene contains just one object with this material applied, lit with hdri which is just a 2k for lighting (transparent background).
Error log:
I0119 02:17:21.456306 12864 device_cuda.cpp:859] Buffer allocate: __tex_image_byte4_025, 42,511,660 bytes. (40.54M) in device memory
I0119 02:17:21.465284 12864 device_cpu.cpp:448] Texture allocate: __tex_image_byte4_025, 42,511,660 bytes. (40.54M)
Skipping auto-save, modal operator running, retrying in ten seconds...
aligned_malloc returns null: len=2976088740 in Cycles Alloc, total 1084153684
Error : Unrecognized Exception
Address : 0x00007FFB63A6A388
Module : C:\WINDOWS\System32\KERNELBASE.dll
Added subscriber: @3di
Added subscriber: @StephenSwaney
That means you ran out of contiguous memory. An attempt to allocate 2,976,088,740 bytes (roughly 3 GB) failed.
Added subscriber: @brecht
We require an example .blend and image file to reproduce the problem. If you can't share the original one, you can create an artificial one.
Normally I would expect allocating 3 GB of contiguous memory to work, if there is enough memory available. With virtual memory it does not actually need to be contiguous in RAM.
Seems to be plenty of space left for the pagefile on the C drive, and the crash happens at around 26GB system ram usage, so there's enough space in system ram for the 3GB it's trying to allocate :
Edit: Just trying to recreate the crash in another file and it wont happen, so retried in the original file and it seems to be not crashing there either now.....strange, I haven't restarted the pc....although I did clear out the app data/temp folder. Would cycles have been pulling any data from that folder during render?
No, Cycles doesn't use that folder.
Best close it down then, shall I reopen this if it happens again, or just leave a new comment so someone else can change the status?
Ok, we can indeed reopen when needed.
