select similar by face angles #73238
Reference: blender/blender#73238
Operating system: Windows-10-10.0.17134-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 630 Intel 4.5.0 - Build 26.20.100.7262
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-27 20:38, hash:
c2a37867f2
[ should be available when face select mode activated. only available on edge select mode and then selecting more edges not necessarily wanted. so you need to toggle to face select mode again. if available would be done in 1 step]
Added subscriber: @zgorg
well apparently this is called then polygon slides. I would never imagine it was the same...
Added subscriber: @Stan_Pancakes
Sides, not slides. I'm not exactly sure what it is that you're having an issue with. Selecting edges by face angles does what it says: selects edges which are on a similar angle between faces. Polygon sides is just that: polygons with the same number of sides, irrespective of angles.
Added subscriber: @rjg
@zgorg please update the description and tell us precisely what you're trying to do and what doesn't work as expected. Additionally we need step by step instruction to reproduce the issue (what steps have you performed in Blender that resulted in the problem).
This comment was removed by @zgorg
ok I get it now... the only point is that the description is a little strange.
there is "face by side" too. this is very close but the fact that we can chose the number of vertices is a better option that a first selection because you can do greater and then reduce the threshold.
https://youtu.be/oNTAiDpPHCw
Changed status from 'Needs User Info' to: 'Resolved'
