Modifiers disabled in viewport are not rendered if the object is in edit mode
Confirmed, NormalPublicBUG
Version 2.83
  1. Open:
  2. Render with the object in edit mode and then in object mode.
Scene in object mode
Render:
Scene in edit mode:
Render:
Cannot reproduce on Linux with an i7-6700K and a GTX980Ti (both CPU and GPU rendering look the same in object and edit mode).
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Jan 24 2020, 1:43 PM
I can confirm the problem.
The problem occcurs because the bevel modifier is disabled in the viewport.
But it should appear in the render, whether or not it is in edit mode.
So this is a bug.
Germano Cavalcante (mano-wii) renamed this task from Multi material object not rendering correctly to Modifiers disabled in viewport are not rendered if the object is in edit mode.Jan 24 2020, 1:48 PM
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
I have the same problem. It occurs in Eevee and in Cycles.
Can confirm 2.82 and 2.81 also have the problem. Didn't check 2.80 though.
