blender crash when adding segments on bevel modifier #73450
6 Participants
Reference: blender/blender#73450
Operating system: Linux-5.4.0-3-amd64-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: AMD Radeon R6 Graphics (CARRIZO, DRM 3.35.0, 5.4.0-3-amd64, LLVM 9.0.1) X.Org 4.5 (Core Profile) Mesa 19.3.2
Broken: version: 2.81 (sub 16), branch: Unknown, commit date: Unknown Unknown, hash:
rBUnknown
Segments
in Bevel modifierfile_updated.blend
Added subscriber: @fikrillah
Added subscribers: @HooglyBoogly, @howardt, @JacquesLucke
It crashes in
snap_to_pipe_profile
due to a failed matrix inversion.Added subscriber: @Pasang
Doesn't crash in my system though...
It might be that it only crashes deterministically in debug builds because an assert is hit in the code. The error might go unnoticed in release builds when you are unlucky.
I'll look into this as soon as I get a chance.
I looked into it some. The problem is that the start and end of some profiles (e.g., for edge 33 between vertices 16 and 93) are the same point. This seems to be because when offset_meet is called during build_boundary, the left and right offsets of beveled edges 33, 35, and 37 are zero. They got set properly in bevel_vert_construct, so not sure where they got reset.
We should fix the snap-to-pipe code to detect when the profile start and end points are the same, and just return the coords of one of those points and avoid the matrix inversion. That will stop the crash. But we should try to figure out why those points are identical in this case, too.
The problem is provoked because the input mesh has some edges that form a zero-degree angle, causing clamp overlap to set the offsets to approximately zero (hence, even with bug fix, this mesh will not bevel noticeably with clamp overlap turned on). Information for bug reporter: an example of the problem are the vertices with indices 44, 17, 73, 10, which form a chain in that order, while it looks like what was intended was that vertex 17 would be in the center of edges going to 10, 73, and 44. You can see vertex indices by selecting Developer Extras in Preferences, then clicking "Indices" in the Display Overlap options, then selecting all the vertices.
My next commit will protect against crashes in this situation and close this bug.
This issue was referenced by
30963eecfb
