Benchmark fails for scene Victor #73648
legacy module
Rendering & Cycles
legacy project
1.0.0-beta.2
legacy project
Blender Benchmark
legacy project
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
Reference: archive/blender-benchmark-bundle#73648
System
Linux 64bit Gentoo
16GB Ram
Over 100GB free disk space (directly available)
Nivida GeForce GTX 1660 Ti
Intel i5-9400f 2.90GHz
Environment
blender-benchmark-cli 2.0.4
blender-benchmark 2.0.4
Issue
Benchmark (GUI or CLI) fails when Victor is included as a scene to render.
All other scenes work fine.
Using 2.81 or 2.81a has the same result (fails for Victor, works for all others)
Using GPU or CPU has the same result (fails for Victor, works for all others)
Have tried "clear_cache" option and manually deleting ~/.cache/blender-benchmark-launcher/
Running
results in
https://pastebin.com/4VWZ5tuA (415.03 KB)
but I cannot see an obvious issue, other than its fails on "Updating Scene BVH | Building BVH"
My system is
Happy to provide any other information on request. Have previously submitted the error using the benchmark GUI.
Added subscriber: @rob_on_earth-1
Added subscriber: @LazyDodo
peak memory for victor on my box is 16774.97M that 16GB of ram may be just a little short there.
Added subscriber: @SemMulder
I believe @LazyDodo is correct here. We are currently still investigating how to detect this properly (detecting the amount of GPU memory available across all brands is a bit complicated). Closing this for now as this is not an issue with the launcher per se.
I tried the Victor scene with an unrelated Windows laptop with 16GB ram and it had the same result.
Setting the number of Samples to 1 and the render size to 10% manually allowed it to complete, so I agree, it is running out of memory in the benchmark.
FYI the Victor scene opens with a text window suggesting 12GB
