Node Wrangler Addon's "Connect to Cycles Viewer Node" broken In EEVEE by rBA8130de948d78
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.83 (sub 2), branch: master, commit date: 2020-02-12 19:49, hash: rB9fe469c11094
Worked: before rBA8130de948d78
When using EEVEE and the Node Wrangler Addon, Ctrl Shift LMB to connect nodes to the Viewer Node only work on Shader Nodes. All other node types return this error instead:
  File "C:\blender-git\build_windows_x64_vc16_Release\bin\Release\2.83\scripts\addons\node_wrangler.py", line 1709, in invoke
    intensity /= pow(2, (context.scene.view_settings.exposure))  # CM exposure is measured in stops/EVs (2^x)
UnboundLocalError: local variable 'intensity' referenced before assignment
Relevant code, lines 1706 and 1708 are new as of rBA8130de948d78
1706                       if context.scene.render.engine == 'CYCLES' and hasattr(context.scene, 'cycles'):
1707                           intensity = 1/context.scene.cycles.film_exposure  # Film exposure is a multiplier
1708
1709                       intensity /= pow(2, (context.scene.view_settings.exposure))  # CM exposure is measured in stops/EVs (2^x)
Start Blender.
Make sure Node Wrangler is enabled.
Add a material to an object in the shader editor.
Add any node type except shader.
Ctrl Shift LMB on the node.
