compositing - transform node - scaling method (bilinear) #73843
Reference: blender/blender#73843
Operating system: windows
Graphics card: gtx680
Broken: 2.82
setting the transform node to "bilinear" gives the same result as using "nearest" - "bicubic" works fine
(scale 0.5 with bilinear looks like scale 0.5 with nearest)
render image - add transform node - scale to 0.5 - compare output using nearest-bilinear and bicubic
Added subscriber: @Golem72
classroom_cuda.blend
open .blend file and render ...
use "switch" in compositing window to compare (change bilinear to bicubic in 2nd transform node to compare again)
Added subscriber: @mont29
No bug here, this is just a consequence of using exact 0.5 factor (other factors do give different results with bilinear vs nearest point methods).
Added subscriber: @EAW
The result of bilinear scaling = nearest scaling for negative integer powers of 2.
2^n where n= -1, -2, -3,...
So 1/2, 1/4, 1/8,...
You happened to pick the first case of 0.5
Try 0.6 or 0.501 and you will see how the algorithms are different. 🙂
