Eevee mipmaps not respecting border mode #73942
6 Participants
Reference: blender/blender#73942
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash:
77d23b0bd7
Also broken 2.83 alpha hash
f6d5a95513
Mipmaps used by Eevee appear to always be generated using tiling border mode, as if texture access mode is just set by modulo coordinates rather than setting the border sampling mode for the hardware.
This is true for both extend and clip modes of texture access.
I can't currently select Cycles rendering engine in 2.82 (presumably a different bug) but the problem doesn't exist in Cycles in 2.83 alpha or in previous versions where I've seen this bug (2.81 and 2.80 if I remember correctly), only in Eevee.
Attached file demonstrates the bug. A plane with a magenta->black gradient texture is set to clip mode. You may need to zoom out to get a visible mipmap demonstrating the problem, as the mipmap chosen should depend on your own personal resolution.
mipclipbug.blend
Change to rendered view. At a suitable zoom, a magenta bar is visible on the rightmost margin of the plane.
Added subscriber: @vasiln
Since this could potentially be related to specific hardware, here's a screenshot:
Also shows up in renders:
Added subscriber: @iss
Seems to happen only with linear interpolation in texture node.
I'm not sure why it behaves as it does, but it does look wrong. I can also confirm that it works as expected in Cycles.
2020-02-18 11-52-22.mp4
Extra info: problem exists regardless of linear, cubic, or smart filtering. No problem, of course, with closest (no mip) filtering.
Added subscriber: @fclem
The issue seems to be that
point_texco_clamp
assumes lod level 0 when querying the texture size. From what I've read, we can't simply clamp between 0 and 1, because textures are sampled at pixel centers. Unfortunately, I could not figure out how access the correct mip map level. Maybe @fclem knows that.This is tricky. We could use textureQueryLod for that matter but this is not supported on all target platform.
What I would prefer is to have different samplers objects for each textures and bind the correct one for each texture nodes.
That's too late for 2.83 so I would leave that open to be tackled for 2.90.
Added subscriber: @EnzioProbst
Another problem with mipmapping happens when using non-continuous texture coordinates like white noise.
I guess the automatic mip level calculation fails as dfdx and dfdy calculation does not make sense for this usage.
This only happens for Linear Interpolation.
Such a setup using white noise can be quite handy for raycasting shaders, blur effects etc.
It would be great to have an option for disabling mipmapping while still doing linear filtering. Would this be supported on all platforms?
Or even better expose a node socket for manually controlling the miplevel. Manual miplevel can also be used for number of effects like cheap blur.
while
textureQueryLod
is not OpenGL 3.3textureLod
is. So manual control should be doable.This issue was referenced by
b2dcff4c21
