Crash: Custom Panel UI Toggle while Undoing #74067
6 Participants
Reference: blender/blender#74067
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.83 (sub 4), branch: master, commit date: 2020-02-21 01:21, hash:
b56957f0af
Broken: 2.82
Broken: 2.81
Read Access Violation when toggling custom UI button and repeatedly undoing. Crash unlikely to happen first time but will happen eventually. In the video, I toggle a few times, then hold Undo while toggling. (Video shows exact steps)
Sometimes it can take a bit of time before the crash happens. It might happen faster if you reload the file then repeat the toggling process.
Open attached .blend File
Run Script
Go to 3DView -> N -> Panel "Crash"
Toggle the button a few times
Hold Undo while continuing to toggle the button.
Crash occurs eventually.
crash_simpler_vid.mp4
crash_simpler1.blend
Below is a pic of where the exception is thrown (Blender version for source pic attached)
Thank you for your time and hard work.
Added subscriber: @wbmoss_dev
Added subscribers: @ideasman42, @mont29
Can reproduce as well, from the backtrace below it's clearly that UI (either editors data, or from the event handling, but I think in that case it's the button' RNA pointer itself) is still using old data from before the undo step, after undo has been performed.
@ideasman42 think I need your knowledge of undo and/or WM here. Looking in undo code I actually cannot find anything enforcing an immediate full redraw/update of the UI right after undo. And I cannot actually locate any function in WM that would allow this?
We do have an
ED_editors_init_for_undo()
, but its scope seems very limited...Note: after undo speedup work is done and in master, this will almost never be an issue anymore, since we'll reuse existing memory... But that will just hide the issue, not actually fix it.
We most likely send a fake mouse move event after the button is pressed, to force a redraw and thus updating the hovered button highlight. So I think it's the UI code causing that redraw, not undo code.
This looks like an issue with the order of event handling, looking into it.
This is a more general issue than undo, this could happen with any operator that frees an ID.
The bug happens rarely because the UI typically refreshes after an operator runs.
This is similar to the problem we ran into where operators needed an evaluated depsgraph, except in this case we need an updated UI.
I don't think this is something we should try solve for 2.83 as it would likely involve changes to event loop handling.
We could change the event system to support early-exit to refresh the UI, then
we could detect operators that free ID's and be sure to refresh before other events are handled.
(Edit, as it's possible for this to happen freeing any non-ID data such as constraints, modifiers etc... we could ensure UI handlers always operate on a interface that's been refreshed after running other non-UI handlers).
Here is a workaround for the bug, showing how exiting the event look early resolves the issue: P1407: #74067 event handling workaround
This shouldn't be used as-is, because clearing the window is intended for the file-read case, and returning early skips setting the previous event values (prevx/prevy).
Added subscriber: @oweissbarth
