Drivers - Invalid python expression after rendering #74080
5 Participants
Reference: blender/blender#74080
Nvidia GTX 780
Broken: 2.82
The property "Use for rendering" in View Layer Properties panel can be driven ... until the first render.
#74080.blend
Driver no longer works
Added subscriber: @thierrykobyleski
Added subscriber: @iss
There was error in system console:
Use this driver expression:
int(frame)%2==0
Driving property "Use for rendering" in View Layer Properties panel fails after first renderto Drivers - Invalid python expression after renderingChanged status from 'Archived' to: 'Confirmed'
Added subscribers: @Sergey, @JacquesLucke
I get a different error in this file.
After some investigation, the issue seems to be that during rendering the scene being rendered contains only one view layer; only the one that is rendered currently. Now, some code tries to find the
Cube
view layer due to the driver while theSphere
view layer is rendered, but does not find it for the reason mentioned above. This produces theinvalid driver
error. Unfortunately, I don't really understand how all of that fits together..I tend to call this a known issue for now. @Sergey, what do you think?
@JacquesLucke, dependency graph always consists from a single view layer (no matter if it's render-only or viewport).
What's supposed to happen is all dependencies is what's used in the view layer are supposed to be pulled into the dependency graph. This means that when dependency graph builds
Sphere
is should see "aha, you need Cube for the driver. Lemme pull it into the dependency graph for you!"There are tricky parts like how to detect whether ID is needed or not. Currently its based on driver variables IDs. As in, if there is an RNA path in the driver expression which references ID which is not in any of the variables then dependency graph will not see it.
So if the ID is referenced from variable "it should just work". It it's something more tricky like that then it's a known issue. Dependency graph can not parse python code to know used IDs. And there is simple workaround: add dependency as variable.
Hope it all makes sense :)
Added subscriber: @dr.sybren
@thierrykobyleski what exactly do you want to achieve by animating the view layer's "use for render" property? The view layer seems to still be used in the compositor on all frames.
It helps us to have some context for the report. Is this an intrinsic issue that blocks an entire studio from working? Some recently introduced problem, where older versions of Blender did this just fine? Or is it just an experiment to see if this could work?
Changed status from 'Confirmed' to: 'Needs User Info'
