OBJ Importing #74088
2 Participants
Reference: blender/blender#74088
Operating system:
Graphics card:
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (optional)
In the 1.79 build of Blender, we were able to convert a SolidWorks file to .obj and then import into Blender with all the parts of that assembly coming in as separate objects. Now, when we import in the 2.8/2.82 version of the build, the .obj files come in as a solid object with all the parts fused together, not allowing us to edit them. Is there a work around for this?
Added subscriber: @Coredawg
Added subscriber: @EAW
Thank you for the report.
Try checking
Split by Groups
in the side panel when you import the .obj file.Does that work?
Due to the fact that the Tracker is currently under Curfew, I will close this report as it doesn't have the required information for us to investigate the issue, such as a simple example .obj file to test.
For more details see:
https://code.blender.org/2019/12/tracker-curfew/
