Expressions during Grab don't work as expected #74163
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#74163
Operating system: Linux-4.15.0-39-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 690/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash:
blender/blender@77d23b0bd7
Blender supports expressions during transform operations (for example, I can enter (15+7)/2instead of calculating it manually), but this feature have realized in a very strange way. I had problems with just entering proper expression during Grab. I found the solution, but it is really strange and counterintuitive.Exact steps for others to reproduce the error
Excuse me for my English, it isn't my mother tongue.
Start Blender, select the default Cube, press G, press Y, then try to enter 15/2
You will see 1/152 instead. This happens because /key switches betweenxand1/xmode. If you press**/again, you will see152**. If you press /again, you will see 1/152. And so on.
Press Esc, then press G and Y again. Try to enter 15+7. You will see 157. This is really confusing.
If you a newbie, you can think that Blender just doesn't support expressions, and you must come to terms with inevitable.
Keep trying. Press Esc, then press G and Y again. Try to enter 15*3. You will see 153. The last ray of hope has gone and darkness has surrounded you. But don't give up. Enter /2and you will see153/2. What? It is a miracle! Now you can enter expressions as you wish. Press and hold Backspace, then enter 15/3 and you will see 15/3, as you expected.
But if you now press Esc, G, Y, and then try to enter 15/3, you will see 153 again.
So, it dawned on you that the hotkey switches betweenno expressionandexpression* mode.
Added subscriber: @denis_russkih
Added subscriber: @Mets
Added subscribers: @WilliamReynish, @mano-wii
In fact, with nothing indicating on the interface that the hotkey {key*} changes between no expression and expression mode, it is very difficult for the user to find out.
Changing the behavior to use with expression by default would not be the best solution since users are used to, for example, changing the signal just by pressing {key-}
And I'm also not sure if the {key *} hotkey is the best choice.
This is something that needs to be studied.
@WilliamReynish, would this be a reasonable task for the
User Interface Module
?How about this solution:
(x is an expression)
By the way, today you can't switch back to no expression mode when you pressed once. The solution that I propose can solve this problem. We just don't needno expressionmode anymore, just by assign another hotkeys tono expression* features.
If you care about numpad users, you can also assign Page Up key as alternative for Space key, and assign Page Down as alternative for Alt.
Added subscriber: @ankitm
https://docs.blender.org/manual/en/latest/interface/controls/buttons/fields.html
It either needs to be documented or hinted about, somewhere in the UI.
Can't say that it's a bug. Code is working as it was
writtenintended.But you can't switch back to no expression mode if you switched to expression mode. Also, this way is extremely counterintuitive, and not so many users read all manuals. Looks like a small font paragraph in a contract.
IMHO, this is not a code bug, but this is an architecture and interface bug. Imagine that you wrote a simple Calc application, but there is no Plus button, only Minus. (You forgot to add Plus.) The code is working as it was written, all code is correct. But there is a bug.
In fact, this is an absolutely usability nighmare. This part of UI is not intuitive, it was designed for aliens.
Maybe we need to create a vote, to find out opinions of users. I am sure that many will agree with me.
https://docs.blender.org/manual/en/2.82/scene_layout/object/editing/transform/control/numeric_input.html
Also, there's Preferences > Input > default to advanced Numeric input.
The current behaviour is documented and working as it was designed. For further Design discussions, Bug tracker isn't the right place.
Thanks! I didn't know that Ctrl+= allows to switch back to Simple mode. Also, I didn't know about the checkbox in Preferences. That's good, I like it.
Sorry to wasted your time for this thread. In fact, Blender already has all that I was need.
