How to run test.sh #74209
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
Reference: infrastructure/blender-open-data#74209
Johan has the following question:
Added subscriber: @fsiddi
Added subscriber: @Walles
There is no CI set up as of yet.
This suggests you are using an old version of
poetry
please use at least1.0.0
.This suggests you are using an old version of
mypy
, did you runpoetry install
?I'm on poetry 1.0.3.
poetry install
run, see below.Maybe you're using the system mypy (0.761) rather than the one mentioned in the repo (0.740), could that be it?
I used the exact same version of poetry (1.0.3) and Python (3.8.1) now. My output is as follows:
If you'd like you can run the same commands with the latest checkout and compare.
Nope, doesn't work, and I don't get why, see below.
But I think that given the current conversation in #73322 I will hold off with trying to change anything, and if it turns out I still want to change stuff after that ticket has been taken care of, I'll get back to this.
Who knows, maybe
$CAUSE
has fixed itself by then?Closing as Invalid for now.
