Fastest CPU / Fastest GPU data skewed #74214
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
2 Participants
Reference: infrastructure/blender-open-data#74214
Hi!
Look at the top graphs here:
https://opendata.blender.org/
From the two top lists you can get these numbers, showing that the AMD CPU is about 1.2x faster than the GeForce card:
However, if you look at benchmark numbers for these two, where both have been run on the same...
... it turns out that it's actually the GeForce card that is faster by a factor of 1.2:
https://github.com/walles/blender-opendata-comparer/tree/walles/toplist
Branch:
walles/toplist
SHA:
4fb12bb13b5e4e5a2e70862b844f76de28ae1ae9
So due to sampling bias, where not all rendering devices have been run under the same conditions, the current comparisons sometimes come out wrong.
Not entirely sure how to do better comparisons unfortunately, but this is something that you may want to think about.
Regards /Johan
Added subscriber: @Walles
Added subscriber: @SemMulder
I think this is mainly due to the CUDA vs OptiX difference (see #73322) and compare the following:
https://opendata.blender.org/benchmarks/query/?device_name=GeForce%20RTX%202080%20Ti&group_by=benchmark&group_by=device_type
https://opendata.blender.org/benchmarks/query/?device_name=Threadripper%203970X&group_by=benchmark
So I'm merging this into #73322.
Closed as duplicate of #73322
