Problems when running 'make update_po' in BASH shell on MacOS #74218
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#74218
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
blender/blender@f1aa4d18d4
Ran the "make update_po" in 'blender_docs' directory on local machine and encountered several problems:
these errors resides in the file
blender_docs/tools_maintenance/update_po.sh
-printf '%h\n
. This option in 'find' command is NOT available on Darwin. There are two occurrences in this file.export LANG="en_US.UTF8
should beexport LANG="en_US.UTF-8"
, ie. with a hyphen betweenF-8
. Thelocale -a
will list out list of all available language codes.is causing the error message:
svn: Skipping argument: E200025: 'locale//vi/.svn' ends in a reserved name
Note there are two '//' in the path. This is caused by the extra forward slash in the 'find locale/..' Remove the slash so the command is only 'find locale ...' resulted to this line:
svn: Skipping argument: E200025: 'locale/vi/.svn' ends in a reserved name
Commented the above block out (svn cleanup and svn up) and the error message is GONE. If you go to the
locale/<lang>
and do thesvn up .
manually, there are no errors encountered.Last, and the most severed is the creation of
locale/locale/<lang_code>
directory and files. This is wrong. (locale) is repeated twice.Recreating problem
Run:
svn checkout https://svn.blender.org/svnroot/bf-manual/trunk/blender_docs
to get the documentation code down the local machine:
run:
then install one language, say vi:
svn checkout https://svn.blender.org/svnroot/bf-manual-translations/trunk/blender_docs/locale/vi locale/vi
Now run the command:
make update_po
Note: The code appeared running OK on Linux Mint, about 1-2 months ago. Presently I do not have access to a Linux machine in order to compare results.
The funny thing is if you just run this from the command line, assuming the environment variable
BLENDER_MAN_EN
is pointing to yourblender_docs
directory:cd $BLENDER_MAN_EN; rm -fr build/locale; make gettext; sphinx-intl --config=manual/conf.py update --pot-dir=build/locale --language="vi"; python3 tools_rst/rst_check_locale.py
and there are no errors
Added subscriber: @hoanguk
Added subscriber: @ankitm
Hi! please use code formatting to separate your comments and commands/output. use three backticks {key `} to start a code block, three to end it.
Added subscriber: @Blendify
find
is a standard bash command.I was able to run just fine on linux, I do not have a mac to test but bash should work identically to linux.
find
is a standard bash command.I was able to run just fine on Linux, I do not have a mac to test but bash should work identically to Linux.
Please verify your system or $path is not corrupt.
Changed status from 'Needs User Info' to: 'Resolved'
No reply.
Sorry for coming back late. I think you'll need to obtain an access to Darwin, somehow, probably from developers who manages the build for MacOS. I ran the test using 'BASH' (did not change to Zsh for fearing the compatibility issues). I've recently updated the SVN source for $BLENDER_MAN_EN (blender_docs) and by mistake reran the
make update_po
again and the mistake is repeated. Please try to obtain a mac machine and try it out first before closing the LOG. I bet there are someone out there using MACOS to manage and build the translation from, not just me alone.
Changed status from 'Resolved' to: 'Needs Triage'
@ankitm I am unable to test, maybe you can triage this and comment on what's going on from the mac side?
Will do. Albeit by this time tomorrow
I did the steps as listed out here, (except installing requirements using conda (I'm not okay with sudo and pip))
For 1:
https://unix.stackexchange.com/a/272493/359891
https://github.com/DerrickWood/kraken/issues/48#issuecomment-320018811
For 2:
yes,
en_US.UTF-8
is the one inlocale -a
Added subscriber: @ideasman42
Instead of the loop at
https://developer.blender.org/diffusion/BM/browse/trunk/blender_docs/tools_maintenance/update_po.sh$47
and at further locations, can we use this ?
SVN_DIRS_ALL
is needed afterwards too, but I'm having some trouble having a nice list of directories (with spaces) without the GNU version offind
.see https://www.unix.com/man-page/mojave/1/find/
CC @ideasman42
@hoanguk please test the differential if it fixes the first 3 points you mentioned above.
