Zero sized normals if the object scale to zero in one axis. #74317
Open
opened 2020-02-29 15:32:30 +01:00 by Shish · 9 comments
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 555X OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: 77d23b0bd7
A 3D object with a reflective texture turns black when flattened by scaling x0 along an axis
I was rendering a transform of a reflective hemisphere from concave to convex, seeing how the reflection changes over time.
  • With Cycles, this works as expected. Concave is warped one way, flat is a flat mirror, convex is warped the other way.
  • With Eevee, the concave and convex reflections are fine, but for one frame where the hemisphere has become a 2D circle, it shows up black.
Example file attached, saved at the half-way point in the animation where this bug occurs: spoon.blend
Videos attached to show the effect just in case this is hardware-specific and only happens on my laptop.
Eevee, with one black frame right in the middle:
spoon-eevee0001-0120.webm
Cycles, everything is fine:
spoon-cycles0001-0120.webm
**System Information** Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits Graphics card: AMD Radeon Pro 555X OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5 **Blender Version** Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: `77d23b0bd7` A 3D object with a reflective texture turns black when flattened by scaling x0 along an axis ~ I was rendering a transform of a reflective hemisphere from concave to convex, seeing how the reflection changes over time. - With Cycles, this works as expected. Concave is warped one way, flat is a flat mirror, convex is warped the other way. - With Eevee, the concave and convex reflections are fine, but for one frame where the hemisphere has become a 2D circle, it shows up black. Example file attached, saved at the half-way point in the animation where this bug occurs: [spoon.blend](https://archive.blender.org/developer/F8380159/spoon.blend) Videos attached to show the effect just in case this is hardware-specific and only happens on my laptop. Eevee, with one black frame right in the middle: [spoon-eevee0001-0120.webm](https://archive.blender.org/developer/F8380166/spoon-eevee0001-0120.webm) Cycles, everything is fine: [spoon-cycles0001-0120.webm](https://archive.blender.org/developer/F8380167/spoon-cycles0001-0120.webm)
Author
Added subscriber: @shish_blender
#97031 was marked as duplicate of this issue
Member
Added subscriber: @Rodrigo_S.T
Clément Foucault changed title from Black reflections in eevee to Zero sized normals if the object scale to zero in one axis. 2020-04-23 18:06:28 +02:00
Added subscribers: @brecht, @fclem
This happens because the object is scaled to 0.0 in one axis.
This also happens for workbench too.
@brecht what does cycles do to prevent this?
This happens because the object is scaled to 0.0 in one axis. This also happens for workbench too. @brecht what does cycles do to prevent this?
It might be this code to invert degenerate matrices:
  if (UNLIKELY(!transform_matrix4_gj_inverse(R, M))) {
    /* matrix is degenerate (e.g. 0 scale on some axis), ideally we should
     * never be in this situation, but try to invert it anyway with tweak */
    M[0][0] += 1e-8f;
    M[1][1] += 1e-8f;
    M[2][2] += 1e-8f;
I doubt Cycles handles scale 0 well in all cases though, in general such transforms with zero scale along one axis should not be expected to give meaningful results.
It might be this code to invert degenerate matrices: ``` if (UNLIKELY(!transform_matrix4_gj_inverse(R, M))) { /* matrix is degenerate (e.g. 0 scale on some axis), ideally we should * never be in this situation, but try to invert it anyway with tweak */ M[0][0] += 1e-8f; M[1][1] += 1e-8f; M[2][2] += 1e-8f; if (UNLIKELY(!transform_matrix4_gj_inverse(R, M))) { ``` I doubt Cycles handles scale 0 well in all cases though, in general such transforms with zero scale along one axis should not be expected to give meaningful results.
Well we use the matrices computed by the depsgraph so that would have to be fixed here.
But since this matrix can be used for other purpose, I would not touch it for the sake of fixing this corner case.
If we were to recompute the inverse matrix again with this fix just for display purpose, we would take a significant performance hit.
Well we use the matrices computed by the depsgraph so that would have to be fixed here. But since this matrix can be used for other purpose, I would not touch it for the sake of fixing this corner case. If we were to recompute the inverse matrix again with this fix just for display purpose, we would take a significant performance hit.
Member
Added subscriber: @Leo-Luther
Philipp Oeser removed the
label 2023-02-09 15:15:08 +01:00
7 Participants
Reference: blender/blender#74317
