Resetting the Theme to default causes most of the texts to disappear #74318
Closed
opened 2020-02-29 15:55:05 +01:00 by irex124 · 42 comments
Graphics card: Intel(R) HD Graphics 400 Intel 4.4.0 - Build 20.19.15.5070
Broken: version: 2.83 (sub 5), branch: master, commit date: 2020-02-28 16:45, hash: 85f980c517
Resetting the Theme to default causes most of the texts to disappear. It also happens when I try to reset to factory settings.
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: Intel(R) HD Graphics 400 Intel 4.4.0 - Build 20.19.15.5070 **Blender Version** Broken: version: 2.83 (sub 5), branch: master, commit date: 2020-02-28 16:45, hash: `85f980c517` **Short description of error** Resetting the Theme to default causes most of the texts to disappear. It also happens when I try to reset to factory settings. ![Screenshot (68).png](https://archive.blender.org/developer/F8380229/Screenshot__68_.png)
Author
Added subscriber: @Pasang
#80027 was marked as duplicate of this issue
#79181 was marked as duplicate of this issue
#78847 was marked as duplicate of this issue
#77407 was marked as duplicate of this issue
#76110 was marked as duplicate of this issue
#75682 was marked as duplicate of this issue
Added subscriber: @iss
Can not reproduce with builtin themes.
Do we have to use some specific theme?
Can not reproduce with builtin themes. Do we have to use some specific theme?
Author
It happens with the built-in themes. Also, today I tried to reset to factory settings and baam ! All most all the texts disappeared.
Seems like igpu problem as it doesn't happen in my other laptop with Nvidia card.
It happens with the built-in themes. Also, today I tried to reset to factory settings and baam ! All most all the texts disappeared. Seems like igpu problem as it doesn't happen in my other laptop with Nvidia card.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Member
Added subscriber: @ankitm
Member
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Member
  • Please update your drivers, if any update is available.
  • Run blender_debug_log.cmd and attach the files it mentions
- Please update your drivers, if any update is available. - Run blender_debug_log.cmd and attach the files it mentions
Author
I just installed the latest graphics driver but the problem still persists.
blender_debug_log file blender_debug_output.txt
blender_debug_gpu file blender_debug_output.txt
blender_debug_gpu_glitchworkaround file
blender_system_info.txt
I just installed the latest graphics driver but the problem still persists. ---- blender_debug_log file [blender_debug_output.txt](https://archive.blender.org/developer/F8383708/blender_debug_output.txt) blender_debug_gpu file [blender_debug_output.txt](https://archive.blender.org/developer/F8383726/blender_debug_output.txt) blender_debug_gpu_glitchworkaround file [blender_debug_output.txt](https://archive.blender.org/developer/F8383750/blender_debug_output.txt) ---- [blender_system_info.txt](https://archive.blender.org/developer/F8383752/blender_system_info.txt)
Member
I don't think so many addons would show up in system info if it were reset to factory settings. Try after removing the blender foundation folder in Appdata
Author
@ankitm, I just tried that but the issue still persists.
@ankitm, I just tried that but the issue still persists. blender_debug_gpu file [blender_debug_output.txt](https://archive.blender.org/developer/F8415936/blender_debug_output.txt) blender_debug_log file [blender_debug_output.txt](https://archive.blender.org/developer/F8415935/blender_debug_output.txt)
Member
Member
Added subscriber: @RodDavis
Member
the common thing in both tasks is: this is 20.19.15.5070 which after updating becomes 20.19.15.5107 but of no help here. I couldn't find the intel drivers for HD 400. The other task has HD 5500 for which I was able to find one.
Author
I updated the driver to 20.19.15.5107 with DriverPackSolution. Unfortunately, the issue stills persist.
This problem wasn't in 2.82a or below.
I wonder if linux or mac has this issue. Sorry, I don't have either os to check.
This problem wasn't in 2.82a or below. I wonder if linux or mac has this issue. Sorry, I don't have either os to check.
Member
@RodDavis or @Pasang could you do a git bisect to find out which commit broke it ?
See this answer by Geoffrey Hale: https://stackoverflow.com/a/37306623 Use 375c7dc4ca in place of <goodcommmit> assuming that 2.82a works.
@RodDavis or @Pasang could you do a git bisect to find out which commit broke it ? See this answer by Geoffrey Hale: https://stackoverflow.com/a/37306623 Use 375c7dc4caf449d40f11d3fd40fa1372636e76d3 in place of `<goodcommmit>` assuming that 2.82a works.
Added subscribers: @xingyzt, @Alaska
Author
Did the bisecting. @ankitm, this seems to be caused by 001f7c92d1
Member
Added subscriber: @mano-wii
Member
Did the bisecting. @Ankit-1 (ankitm), this seems to be caused by 001f7c92d1
CC @mano-wii
> Did the bisecting. @Ankit-1 (ankitm), this seems to be caused by 001f7c92d1 CC @mano-wii
Added subscriber: @ESAB
Added subscriber: @Brelidav
Added subscriber: @Mortar
Added subscriber: @fergicide
Confirming this is a regression for Windows build and Intel graphics introduced with 2.83.0. It was not present in 2.82a.
My system: Windows 10 1903, Intel Compute Stick (STK1AW32SC).
UI text normal upon program start. When I attempt to increase or decrease the text via
EDIT > PREFERENCES > INTERFACE > RESOLUTION SCALE, using the plus/minus buttons, almost all UI text disappears. Resetting to 1.0 does not restore the text.
system-info.txt
Confirming this is a regression for Windows build and Intel graphics introduced with 2.83.0. It was not present in 2.82a. My system: Windows 10 1903, Intel Compute Stick (STK1AW32SC). UI text normal upon program start. When I attempt to increase or decrease the text via EDIT > PREFERENCES > INTERFACE > RESOLUTION SCALE, using the plus/minus buttons, almost all UI text disappears. Resetting to 1.0 does not restore the text. [system-info.txt](https://archive.blender.org/developer/F8762507/system-info.txt) ![driver.PNG](https://archive.blender.org/developer/F8762542/driver.PNG)
Additionally confirming this bug affects 2.83.5, on Windows 10 (1909).
Added subscriber: @Tabra
Added subscriber: @rjg
The triaging team is currently working through old reports. Could everyone affected by this problem check if this still happens in current versions of Blender?
Hi, tried with 2.83.9, 2.90.1, 2.91.0 and a recent release of 2.92. I could only replicate the bug with 2.83.9 and 2.90.1, so the problem is fixed with 2.91.0 and newer.
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Richard Antalik self-assigned this 2020-11-26 16:44:11 +01:00
@Tabra Great to hear this, Will close the report then.
If problems persist we can reopen. Please provide version tested and hardware info when reporting problems.
@Tabra Great to hear this, Will close the report then. If problems persist we can reopen. Please provide version tested and hardware info when reporting problems.
10 Participants
Reference: blender/blender#74318
