Editing mesh.vertices.co in frame_change_pre handler and export mesh as alembic causes random crash and results in a static mesh #74339
Reference: blender/blender#74339
Operating system: Windows 10.0.18363.657
Graphics card: GeForce RTX 2080
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash:
77d23b0bd7
, type: Releasebuild date: 2020-02-13, 01:56:46
I made an addon that reads obj file per frame and changes an object.data.vertices- [x].co by a for loop.
blender plays well in viewport
but when i try to export an alembic. it outputs a static mesh.and sometimes blender goes crash
full addon is in the zip
T74339_edit.blend
Run this script and click play(changes timeline). The monkey should be deformed.
Then export the alembic. Import it back, it is static.
demo.zip
Added subscriber: @MoePus
Added subscriber: @ankitm
Not sure Bug tracker would be a good place to debug an Addon. Can the bug be redone with simpler steps ?
Yes. A simple setup is:
Cannot redo. you find it static because there was no movement on the money before exporting?
I did the same steps, with some keyframes and here's the alembic and the blend file #74339.abc
#74339.blend
T74339_edit.blend
Oh yeah. there's a static mesh.
as a workaround, https://docs.blender.org/api/current/bpy.types.bpy_struct.html#bpy.types.bpy_struct.keyframe_insert
Added subscriber: @mano-wii
I can't reproduce the crash you can try the latest daily build: https://builder.blender.org/download/
I'm also not sure if the fact that alembic doesn't create an animated mesh with this script is a bug.
I suggest you ask on support sites: https://www.blender.org/support/
Use T74339_edit.blend and add a Subdivision Modifier then apply.
Finally export alembic, Blender may crash.
Crash Log on 2.90-542ff416e274
https://developer.blender.org/P1386
Could you please edit that comment and replace the log with https://developer.blender.org/P1386 ?
it does crash, around frame 42.
Not confirming because of the script.
Added subscriber: @iss
I can not reproduce any crash here as well (using 2.90 build). Can not check
542ff416e274
to see if this has been resolved. Can you check again with latest 2.90 build?The fact, that exported mesh is static is likely correct, since alembic exporter uses own dependency graph.
Thank you.
It does not crash in the lastest 2.90 build.
And is there any plan to support export abc of a python api modified mesh? (though i dont need it now)
Not sure about abc exporter, but AFAIK feature to access render depsgraph(which is also separate) would be nice to have, but I am not aware of any concrete plans.
If there is no crash I will close this report as there is no bug. Thanks for reporting anyway.
