eGPU doesn't get used by EEVEE on Windows (Mac / Bootcamp) #74352
8 Participants
Reference: blender/blender#74352
Operating system: Windows 10 1903 (Bootcamp)
Graphics card: Radeon RX 560, Radeon RX Vega 64
Device: Macbook Pro 15" 2018
Broken: 2.82
While using a eGPU on Windows 10 via Bootcamp, Blender doesn't use the external GPU to accelerate and power EEVEE. No matter if the Blender Graphic Setting preferences are set to High Performance, ergo utilizing the RX Vega 64 in any scenario. Missing usage of the external GPU can be tracked via the Task Manager -> Performance Tab. (See screenshots).
**Note 1:**Cycles on Windows/OpenCL recognize and uses the external GPU with no issue as expected.
Note 2: On Mac OS Catalina, EEVEE can use the external GPU as expected by enabling the option 'Prefer External GPU'.
So the problem affects only Windows when an external GPU is used for EEVEE only.
Added subscriber: @mix1189
Added subscriber: @Jeroen-Bakker
@mix1189: have you selected the eGPU to be the primary GPU before starting Blender. OpenGL only works on primary GPU. Most OS's have this option (similar to the
Prefer External GPU
option).Please attach the system-info.txt generated from Blenders help menu. This will show what GPU the OS has selected to use as primary GPU.
Hi Jeroen,
yes, I set the eGPU to be primary for Blender using the recommended Windows feature via the Graphic Settings.
See link: https://www.howtogeek.com/351522/how-to-choose-which-gpu-a-game-uses-on-windows-10
Here's a copy of the system-info.txt from my Blender. I noticed that the Radeon RX 560 is used as the main rendered on the OPEN GL section.
system-info.txt
The expected result should be the RX Vega 64. Apparently Blender is ignoring the option set in Windows.
Added subscriber: @mano-wii
I have experience in choosing the GPU that is used in Blender.
Using Graphics Settings is one way, but you can also use Radeon's own utilities.
The times I had a problem with this were due to poor driver installation.
For information on installing the latest graphics driver see https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13586 Core Profile Context 19.50.01.05 26.20.15001.5006
Hey @mano-wii ,
thanks for the tip but unfortunately this doesn't seem to be the root of the issue.
I ran some tests and made the following findings. Worth to mention that I've updated my setup with a NVIDIA 2070 Super and I have the same exact problem.
I did a clean install of all the drivers on my Macbook Pro, using DDD (Both AMD and NVIDIA drivers). I've also tested multiple NVIDIA driver versions, but got the same results, aka, no eGPU acceleration for Blender while using only the internal display. I'm already on the latest NVIDIA drivers.
Basic 3D apps, like Paint 3D seems to work and properly use the eGPU via the internal display. (I set their graphic preferences via Windows Graphic Setting).
Using the NVIDIA control panel I've set my 3D settings to be forced to use the 2070 Super and the High Performance Mode (Global and Blender.exe). Blender seems to ignore these settings as well.
Now's here where things get interesting...I connected an external monitor to the eGPU and set the latter as my primary display. Launching Blender from the external monitor will let it use the eGPU as expected (Alongside the laptop dGPU, which is not optimal).
After moving the main Blender window from the external display into the laptop internal display, Blender will still use the acceleration from the eGPU.
Unplugging the external monitor, without closing the Blender window, will keep the Blender viewport on the eGPU acceleration. But relaunching Blender from the internal display will still ignore the eGPU.
So looks like Blender is not capable to use the eGPU to accelerate the viewport on Windows (ignoring any option from Windows Graphic Setting and the NVIDIA dedicated panel), if opened from the internal laptop display without any external monitor connected.
I'm attaching two system info reports that have been generated by using only the internal display and the both internal and external displays.
system-info-2070-internal-only.txt
system-info-2070-external-display.txt
On my laptop with a dedicated and integrated video card it works normally.
Apparently it takes a developer with a multi-GPU setup to test.
Added subscriber: @Alej
Have you tried plugging a 'ghost' HDMI or DP headless dongle on the eGPU?
I'm on a path to get into Blender full-on and had similar questions about how this is all working out
Have seen several videos and forums where it would fix similar issues on other softwares (mostly MacOS editing suites mind you, but I think it would be the same).
(Check on amazon for HDMI Headless Dongle, not expensive at all)
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscriber: @EthanSherriff
Added subscriber: @iss
@mix1189 I am looking at older reports, is this still an issue? Or have anything changed?
