Wrong description in the property of the Cube Projection Mapping #74414
2 Participants
Reference: blender/blender#74414
Broken: version: 2.83 (sub 6), branch: master, commit date: 2020-03-03 18:38, hash:
31aefdeec5
When you perform the
Cube Projection
UV Mapping
operation, you see on theRedo Panel
a property called "Cube Size" - "Size of the cube to project on".So you espect the input value represent a 3d cube with that size.
But when you use the tool the input is the divider of the cube size.
So, for example, if you wants a mesh of size 2 to be projected on a cube size of 3, you don't write the value 3.0 to the "Cube Size", but you write the result of 2/3 (0.66).
Cube Projection
You will see a output UV like this, that is the UV expected when you use a cube of size 3x3x3
If you put an input of 2.0, this does not mean a cube with size 2x2x2, you obtain an UV like if the projection cube is twice the size (4 meters)
Added subscriber: @AlbertoVelazquez
Added subscriber: @mano-wii
After pressing U, which of the projection options do you choose?
Cube Projection
Cube Projection Mapping Tool uses incorrect input valueto Wrong description in the property of the Cube Projection MappingChanged status from 'Needs User Info' to: 'Confirmed'
