Freestyle render removes texture image user #74417
5 Participants
Reference: blender/blender#74417
Graphics card: GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.41
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash:
77d23b0bd7
Freestyle linestyle texture goes missing every time I open the file.
freestyle.zip
Added subscriber: @Oye_LKY
Added subscriber: @brecht
It seems no file got attached?
Freestyle texture Bugto Freestyle texture not getting saved despite getting renderedfreestyle.zip
There you go. I think this should work.
Freestyle texture not getting saved despite getting renderedto Freestyle render removes texture image userI think I found the culprit.
When rendering starts:
BlenderStrokeRenderer::RenderStrokeRepBasic(…)
there is a call toGetStrokeShader(…, do_id_user=false)
.do_id_user=false
, thentreeCopyTree_ex()
does not increase the user count for the copied node tree.When rendering stops:
Now the image datablock has no users, and will not be saved. Rendering twice shows an error on the console about a negative user count.
The simplest fix is just to remove the freeing of all the materials. This works, and when Blender quits it doesn't complain of any memory leaks. I'll do some more tests with ASAN to check whether this is really the right way to go.
So I tried it again. I found a trick for this.
This time I turned on the fake user. When I reopened the file, the image was present.
Don't know if this will really help. But I think I'll just inform.
Added subscribers: @IRIEShinsuke, @kjym3
@kjym3 @IRIEShinsuke what do you think about the fix I described in my previous comment? From what I can see it works well (I also tested on https://download.blender.org/demo/test/AtvBuggy.zip) and causes no crashes or warnings about memory leaks.
I did some more testing, and with or without my code, there are the same number of calls to
material_free_data()
andntree_free_data()
, strengthening my hypothesis that the removed code is unnecessary.@Oye_LKY Thanks for the problem report. Using fake users fully makes sense as a workaround, because the reported bug is caused by a wrong decrement of image data block user counts.
@dr.sybren Many thanks for looking into the issue. I confirmed that your proposed fix indeed resolved the problem and no side-effect was seen.
The code segment you proposed to remove was intended to release a material auto-generated by BlenderStrokeRenderer::GetStrokeShader() every time a Freestyle rendering process takes place.
Removing the code seems inappropriate because of a risk of memory leaks. I have no idea why no such leak is seen though.
I tried to address the reported issue by properly incrementing the user counts of image data blocks referenced from texture nodes in Freestyle line style node trees.
I have a few questions with respect to my solution:
If you or some other main developers could answer these questions, I would be greatly appreciate it.
This issue was referenced by
ba8d819c9b
Temporary datablocks used for rendering should not increase user counts on datablocks that are actually part of the .blend file, or modify them in any way that might be visible in the user interface or Python API.
This is all more complicated than it should be though. There is no reason for the
freestyle_bmain
to exist beyond the lifetime ofBlenderStrokeRenderer
, that's a leftover from Blender Internal. We can just free the entire thing and not bother trying to manually free particular datablocks.Changed status from 'Confirmed' to: 'Resolved'
Awesome. You guys are the best.
