Adaptive sampling breaks value Shader AOV's #74572
Closed
opened 2020-03-09 12:21:03 +01:00 by J-P Busse · 24 comments
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.83 (sub 6), branch: master, commit date: 2020-03-06 22:46, hash: dcdcc23488
Value shader AOV's are broken after enabling adaptive sampling.
The Images are showing a simple noise texture plugged into the Value slot of an AOV output.
Expected result (no adaptive sampling):
Adaptive Sampling GPU only:
Adaptive Sampling CPU only:
Adaptive Sampling CPU+GPU:
Using a realy low adaptive threshold fixes the problem but it basically eliminates the purpose of AS.
Plugging the texture into the Color slot and setting the AOV also to color fixes the Problem.
  • create a noise texture node in the Material of the default cube
  • plug it into a AOV output node as a Value
  • create a new Shader AOV pass referencing the AOV node and setting it to value
  • enable Adaptive sampling
  • render: the AOV pass is broken
  • plug the texture into the color slot and set the AOV pass to color
  • render: the resulting pass is as expected
  • disableing adaptive sampling also fixes the problem
Adaptive_Sampling.blend
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19 **Blender Version** Broken: version: 2.83 (sub 6), branch: master, commit date: 2020-03-06 22:46, hash: `dcdcc23488` Worked: (optional) **Short description of error** Value shader AOV's are broken after enabling adaptive sampling. The Images are showing a simple noise texture plugged into the Value slot of an AOV output. Expected result (no adaptive sampling): ![No_AS.jpg](https://archive.blender.org/developer/F8397173/No_AS.jpg) Adaptive Sampling GPU only: ![AS_GPU.jpg](https://archive.blender.org/developer/F8397177/AS_GPU.jpg) Adaptive Sampling CPU only: ![AS_CPU.jpg](https://archive.blender.org/developer/F8397179/AS_CPU.jpg) Adaptive Sampling CPU+GPU: ![AS_CPU+GPU.jpg](https://archive.blender.org/developer/F8397182/AS_CPU_GPU.jpg) Using a realy low adaptive threshold fixes the problem but it basically eliminates the purpose of AS. Plugging the texture into the Color slot and setting the AOV also to color fixes the Problem. **Exact steps for others to reproduce the error** - create a noise texture node in the Material of the default cube - plug it into a AOV output node as a Value - create a new Shader AOV pass referencing the AOV node and setting it to value - enable Adaptive sampling - render: the AOV pass is broken - plug the texture into the color slot and set the AOV pass to color - render: the resulting pass is as expected - disableing adaptive sampling also fixes the problem [Adaptive_Sampling.blend](https://archive.blender.org/developer/F8397215/Adaptive_Sampling.blend)
Author
Added subscriber: @Jan-PhilipBusse
J-P Busse changed title from Adaptive sampling breaks Shader AOV to Adaptive sampling breaks value Shader AOV's 2020-03-09 12:21:43 +01:00
Added subscriber: @Stefan_Werner
Author
I just noticed that the AOV pass gets somehow the sample count pass as an Alpha chanel which makes the AOV pass basically unusable for compositing, I don't realy know whats going on here. Just view the AOV pass as Color and alpha or with a viewer node in the compositor. I had no luck recovering the pass so far.
By the way CPU+GPU rendering seems to be broken with adaptive sampling.
This is the Sample Count pass:
I just noticed that the AOV pass gets somehow the sample count pass as an Alpha chanel which makes the AOV pass basically unusable for compositing, I don't realy know whats going on here. Just view the AOV pass as Color and alpha or with a viewer node in the compositor. I had no luck recovering the pass so far. By the way CPU+GPU rendering seems to be broken with adaptive sampling. This is the Sample Count pass: ![Debug_Sample_Count.jpg](https://archive.blender.org/developer/F8397479/Debug_Sample_Count.jpg)
Member
Added subscriber: @KonstantinsVisnevskis
In my case Adaptive Sampling adds noisy dilatated (3x3px) shading mixed into AOV (both color and value).
Expected solid white mask:
In my case Adaptive Sampling adds noisy dilatated (3x3px) shading mixed into AOV (both color and value). Expected solid white mask: ![mask0022-e.jpg](https://archive.blender.org/developer/F8417970/mask0022-e.jpg)
Added subscriber: @Hell2o
It looks like the issue is that AOV Values aren't being normalised to the actual sample count but to the max samples. a workaround is to divide the AOV value by the debug sample count value in the compositor (see attached files)
AOV Test.blend
AOV Test workaround.blend
It looks like the issue is that AOV Values aren't being normalised to the actual sample count but to the max samples. a workaround is to divide the AOV value by the debug sample count value in the compositor (see attached files) [AOV Test.blend](https://archive.blender.org/developer/F8436924/AOV_Test.blend) [AOV Test workaround.blend](https://archive.blender.org/developer/F8436923/AOV_Test_workaround.blend)
This issue was referenced by blender/cycles@00ef44b46e
This issue was referenced by blender/cycles@00ef44b46ebb66cae67eeb8dcd7ba804e450d688
This issue was referenced by 82a8da0ec3
This issue was referenced by 82a8da0ec38a70efde4a91957824c67d0e60b8ad
Brecht Van Lommel self-assigned this 2020-04-03 13:15:58 +02:00
This issue was referenced by blender/cycles@c6742cdd1f
This issue was referenced by blender/cycles@c6742cdd1f97f44bf897340711aa11e57ec24279
This issue was referenced by 10f0e003a9
This issue was referenced by 10f0e003a95a9d28be162605d7985c4d4620f6c0
This issue was referenced by blender/cycles@0c170f7dae
This issue was referenced by blender/cycles@0c170f7daebf6a5168511ec16dbc763416f61423
This issue was referenced by e05552f7c4
This issue was referenced by e05552f7c4ac27faa510048e8c010e4323acb569
Author
Sry to say it but now an Value AOV breaks even the combined pass:
Build hash: 10f0e003a9
The Szene is the same as the Step by Step guide in the initial post with factory settings.
Strangly: If I set the Tile size to 16px or 32px, the GPU renders fine, if I set it higher to 64px, the result is the same as with CPU rendering.
Sry to say it but now an Value AOV breaks even the combined pass: ![untitled.png](https://archive.blender.org/developer/F8454184/untitled.png) Build hash: 10f0e003a95a The Szene is the same as the Step by Step guide in the initial post with factory settings. Strangly: If I set the Tile size to 16px or 32px, the GPU renders fine, if I set it higher to 64px, the result is the same as with CPU rendering.
Are you entirely certain you tested 10f0e003a9 and not a revision right before that? Since this looks like the problem caused by the commit I reverted.
Or maybe there was some refresh issue on the buildbot, and the very latest build helps.
https://builder.blender.org/download/
I can't reproduce this problem in any case.
Are you entirely certain you tested 10f0e003a95a and not a revision right before that? Since this looks like the problem caused by the commit I reverted. Or maybe there was some refresh issue on the buildbot, and the very latest build helps. https://builder.blender.org/download/ I can't reproduce this problem in any case.
Author
Yes I'm sure, I also tested the latest build 53981c7fb6 with the same result.
exact steps:
  1. load system defaults and switch to cycles
  2. go to the shading tab
  3. add a noise texture
  4. plug the fac into the value of an output aov
  5. name the AOV "AOV"
  6. enable adaptive sampling
  7. add a AOV layer and set it to value (its default name is AOV)
  8. render
system-info.txt
I also tested on two different mashines, one Intel i7 7700K and one Ryzen 2700x, both with Nvidia cards. Maybe the system-info helps?
Yes I'm sure, I also tested the latest build 53981c7fb6fd with the same result. exact steps: 1. load system defaults and switch to cycles 2. go to the shading tab 3. add a noise texture 4. plug the fac into the value of an output aov 5. name the AOV "AOV" 6. enable adaptive sampling 7. add a AOV layer and set it to value (its default name is AOV) 8. render [system-info.txt](https://archive.blender.org/developer/F8455348/system-info.txt) I also tested on two different mashines, one Intel i7 7700K and one Ryzen 2700x, both with Nvidia cards. Maybe the system-info helps?
Member
Added subscriber: @lichtwerk
Member
Changed status from 'Resolved' to: 'Confirmed'
Member
I'd say I can confirm what @Jan-PhilipBusse says (in a3c1605581)
#74572.blend
@brecht: mind checking again?
I'd say I can confirm what @Jan-PhilipBusse says (in a3c1605581) [#74572.blend](https://archive.blender.org/developer/F8456505/T74572.blend) @brecht: mind checking again?
This issue was referenced by blender/cycles@bacc90ff57
This issue was referenced by blender/cycles@bacc90ff57dcc92a8ad946a1b540f6ec6e06e30d
This issue was referenced by 91d7f5d246
This issue was referenced by 91d7f5d2463495f20f1e3a985241a2672961ad3f
6 Participants
Reference: blender/blender#74572
