Crash when trying to delete particle system or undo CTRL+Z #74786
Reference: blender/blender#74786
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash:
375c7dc4ca
Worked: 2.79
After updating from 2.79 to 2.8 this file file crashes when I try to delete the Plane. When I go to Edit mode, trying to rotate, grab or do anything it crashes. Plane has a particle system on it. When i try to delete it crashes too. Basically if i touch the Plane in any way it will crash and there is no way to get rid off it. Cannot delete the particle system either. Also, when i try to undo the last step CTRL it also makes it crash.
Crash.
T74786_2-83.blend
Added subscriber: @kokotek
Added subscriber: @mano-wii
Something is wrong with the attached file.
Please submit again.
Added subscriber: @ankitm
https://developer.blender.org/file/edit/8408189
change the file view permissions
crash plane.blend
I chaned in 'Get info' read and write to 'Everyone'. Is that what you meant? Sorry, this is the first time I'm submitting
I copied the contents in a 2.83 empty file & even things like changing visibility of plane crashes it. T74786_2-83.blend
Ok, so the issue here is that the particles have hair data, even though though they are not hair particles.
When the COW copy is made by the depsgraph, it will make a shallow copy of the
particle_data->hair
pointer. If the particle system type would beHair
, it would make deep copies of the hair data for every particle. Now, when the particle system is removed, it will remove the hair data on the original object and on the cow object. Since both are pointing to the same hair data, there is a double free.Possible solutions:
psys_copy_particles
so that it either always copies the hair data, or sets the hair data tonull
on every particle.readfile.c
. Doing that is a bit tricky, because the particle type is not known during direct linking afaik. So, it would have to be done during/after library linking.I couldn't figure out where this incorrect particle state comes from, yet. I was not able to reproduce it from scratch in a new file.
@kokotek @ankitm, is one of you able to reproduce the issue in a new file, without copying anything from another file?
If it's just adding a plane and applying a particle modifier to it, then no. I can move it around, change its visibility, get nice bubbles out of it, make it hair, back to emitter etc.
Also, the original file will crash if you open it, click in viewport, attempt to close it and pick "don't save" . Though that can be the undo step as said in the report.
Same thing here, in a new file everything works fine, lets me add particle system , emitter, hair...works ok.
when I append the problematic Plane from Crash plane file i will crash straight away.
