Use after free when merging specific areas
Closed, ResolvedPublicBUG
Graphics card: Intel(R) Iris(R) Pro Graphics 580 Intel 4.5.0 - Build 26.20.100.7529
Broken: rB37e7e1e77c3
Crash/use-after-free when merging some regions.
With the attached file:
  1. Merge viewport into the text editor
  2. Merge viewport intro the clip editor
  3. BOOOM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Mar 16 2020, 9:39 PM
Actually no need to use a 10MB sample file or do any of the stated initial merging.
  • Start with factory startup (I used 2.83 master).
  • Change 3D Viewport to Movie Clip Editor
  • On Header, select "Open" and choose any image file
  • Merge Timeline (the editor below it) into Clip Editor. Crash
It crashes in ui_handler_panel() with invalid userdata sent to it.
Merging in the other direction (from Clip Editor) works fine. Also changing the Clip Editor context from "Tracking" to "Mask", everything works. Change view from "Clip" to "Graph" or "Dopesheet", everything works.
