"Normal Map" node in material slows undo after entering viewport render mode #75051
2 Participants
Reference: blender/blender#75051
Operating system: windows 10
CPU: 3950x
Graphics card:2080ti
Broken: 2.82, 2.83-94b8166a8b05
Worked: never
Having a normal node in the shader slows down undo when moving objects then undoing.
This seems to need a scene with decent complexity. I made a new scene and wasn't able to get the same effect.
I know some work is going on with 2.83 undo performance so tested there with the same issue and I thought this report may help.
Open blend file normal map undo bug.blend.
Notice how in the shader editor there is a "Normal Map" node (although no images as they didn't seem to be essential).
Move object, then undo, and notice how the undo is slow.
Delete or Mute the "Normal Map" node.
Move object, then undo, and notice how the undo is significantly faster.
You may need to be in render viewport mode, if loading the scene with render mode not active the slow undo doesn't seem to happen until render mode is entered.
Added subscriber: @FrankieHobbins
Added subscriber: @brecht
We're aware of this performance issue, it's not considered a bug at the moment but considered a to do to work on at some point. When using normal maps, tangents must be generated which take a while to compute. Ideally with improved undo they will be preserved through undo steps.
