Blender stopped working. #75067
Reference: blender/blender#75067
Operating system: Windows 10
Graphics card: intel(R) HD Graphics 630
Broken: (2.80. 2.82)
Worked: (none)
Blender 2.80 was working and then is just stopped and would not start it would just flash and then turn off so I downloaded 2.82 and it did the same thing and the debug start didn't work ether so I updated my drivers and now the debug start works fine but the normal application does not start. this is what the cmd list says.
gputexture: texture alloc failed. likely not enough video memory.
current texture memory usage : 0.00 mib.*
Added subscriber: @CarriEstabrook
This comment was removed by @CarriEstabrook
Added subscriber: @ankitm
Try a restart
I did several times but nothing happens.
Iv'e looked this problem up and everything points to my graphics card but I don't see how blender can work one day and just stop the next but the computer and everything else works exactly the same.
you can update regardless (:ah I can't read#72098 (Crash on startup with 2.82 and Intel HD + Windows)
yes that is the same thing that I have.
can we get a system info ? if possible both from crashing(cmd script) and non crashing versions(help > save system info) (or cmd script also)?
this is the cmd from trying to run blender from the shortcut.
C:\Users\ranch>C:\Users\ranch\Desktop\blender.lnk
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: texture alloc failed. Likely not enough Video Memory.
Current texture memory usage : 0.00 MiB.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
found bundled python: C:\Program Files\Blender Foundation\Blender 2.82\2.82\python
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1515, h : 26, d : 0, comp : 4, size : 0.15 MiB
Current texture memory usage : 0.15 MiB.
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF7403E72E3
Module : C:\Program Files\Blender Foundation\Blender 2.82\blender.exe
Go to Blender installation directory and you'll find the cmd scripts. Run the blender_debug_log.cmd and upload the two files it mentions.
(also put your comment above in a text file and upload it ) (you can edit comments )
If it crashes with
script, runblender_debug_gpu_glitchworkaround.cmd
and rename and upload the two files it mentions again. Please tell if it crashes now.Changed status from 'Needs Triage' to: 'Needs User Info'
blender_system_info.txt
blender_debug_output.txt
these are the blender_debug_gpu.
and these are the blender_debug_gpu_glitchworkaround.
this is the blender_debug_log.
with all the starts it started and then crashed almost instantly.
blender.exe CMD.txt
this is the cmd running blender.exe from the file.
The driver currently installed is
26.20.100.7263
https://www.dell.com/support/home/in/en/inbsd1/drivers/driversdetails?driverid=654r9
last updated: 13 Dec 2019
You should be using the one by intel,
26.20.100.7985
https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630
last updated: 25 march 2020
Closed as duplicate of #72098
Added subscriber: @brecht
I'm going to assume this is the same issue as #72098 (Crash on startup with 2.82 and Intel HD + Windows) since the system specs are similar.
If that's solved, we can re-evaluate to see if there were multiple different issues.
When I downloaded the driver it would not install on my computer and this is the message that I got.
The driver being installed is not validated for this computer please obtain the appropriate driver from the computer manufacturer.
There are ways around that:
https://www.howtogeek.com/343287/how-to-fix-the-driver-being-installed-is-not-validated-for-this-computer-on-intel-computers/
I think the chance of that driver update fixing the issue is rather low though, so it's up to you if you think it's worth trying.
ok thank you.
ok I did that. now it doesn't even flash on and off. and here is the cmd run log.cmd blender.txt
and the new blender debug log.blender_system_info.txt
