Crash | Mataflow Liquid Sim | when using Obstacle with Armature and Sampling Substeps > 0 #75111
Closed
opened 2020-03-26 18:40:44 +01:00 by Michał Wieczorek · 6 comments
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.83 (sub 11), branch: master, commit date: 2020-03-26 09:19, hash: c547d431eb
When there is an object with armature (set to obstacle) and there is Sampling Substeps option enabled (with value more than 0) blender crashes on the beginning of fluid simulation. 0%
Create basic Liquid Simulation environment.
Add obstacle with animated armature
set sampling substeps to for example 2
start liquid simulation
[Based on the default startup or an attached .blend file (as simple as possible)]bug.blend
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19 **Blender Version** Broken: version: 2.83 (sub 11), branch: master, commit date: 2020-03-26 09:19, hash: `c547d431eb` Worked: (newest version of Blender that worked as expected) **Short description of error** When there is an object with armature (set to obstacle) and there is Sampling Substeps option enabled (with value more than 0) blender crashes on the beginning of fluid simulation. 0% **Exact steps for others to reproduce the error** Create basic Liquid Simulation environment. Add obstacle with animated armature set sampling substeps to for example 2 start liquid simulation [Based on the default startup or an attached .blend file (as simple as possible)][bug.blend](https://archive.blender.org/developer/F8429044/bug.blend)
Added subscriber: @michal1000w
Member
Added subscriber: @ankitm
Member
Member
It crashes while baking
Blender[33943:176066] [AudioHAL_Client] HALC_ProxyIOContext.cpp:1399:IOWorkLoop:  HALC_ProxyIOContext::IOWorkLoop: failed to send the final message to the server, Error: 0x10000003
(lldb)
- 0    bb_combineMaps at source/blender/blenkernel/intern/fluid.c:792
- 1    update_obstacles at source/blender/blenkernel/intern/fluid.c:1301
- 2    manta_step at source/blender/blenkernel/intern/fluid.c:3590
- 3    BKE_fluid_modifier_processDomain at source/blender/blenkernel/intern/fluid.c:4002
- 4    BKE_fluid_modifier_process at source/blender/blenkernel/intern/fluid.c:4034
- 5    BKE_fluid_modifier_do at source/blender/blenkernel/intern/fluid.c:4046
- 6    applyModifier at source/blender/modifiers/intern/MOD_fluid.c:119
- 7    modwrap_applyModifier at source/blender/blenkernel/intern/modifier.c:960
- 8    mesh_calc_modifiers at source/blender/blenkernel/intern/DerivedMesh.c:1179
- 9    mesh_build_data at source/blender/blenkernel/intern/DerivedMesh.c:1767
- 10	  makeDerivedMesh at source/blender/blenkernel/intern/DerivedMesh.c:1900
- 11	  BKE_object_handle_data_update at source/blender/blenkernel/intern/object_update.c:193
- 12	  BKE_object_eval_uber_data at source/blender/blenkernel/intern/object_update.c:385
- 13	  decltype(std::__1::forward<void (*&)(Depsgraph*, Scene*, Object*)>(fp)(std::__1::forward<Depsgraph*>(fp0), std::__1::forward<Scene*&>(fp0), std::__1::forward<Object*&>(fp0))) std::__1::__invoke<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339
- 14	  std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__apply_functor<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, 0ul, 1ul, 2ul, std::__1::tuple<Depsgraph*&&> >(void (*&)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>&, std::__1::__tuple_indices<0ul, 1ul, 2ul>, std::__1::tuple<Depsgraph*&&>&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2216
- 15	  std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>::operator()<Depsgraph*>(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2249
- 16	  decltype(std::__1::forward<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&>(fp)(std::__1::forward<Depsgraph*>(fp0))) std::__1::__invoke<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339
- 17	  void std::__1::__invoke_void_return_wrapper<void>::__call<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__functional_base:349
- 18	  std::__1::__function::__func<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>, std::__1::allocator<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&> >, void (Depsgraph*)>::operator()(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1562
- 19	  std::__1::function<void (Depsgraph*)>::operator()(Depsgraph*) const at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1913
- 20	  DEG::(anonymous namespace)::evaluate_node(DEG::(anonymous namespace)::DepsgraphEvalState const*, DEG::OperationNode*) at source/blender/depsgraph/intern/eval/deg_eval.cc:116
- 21	  DEG::(anonymous namespace)::deg_task_run_func(TaskPool*, void*, int) at source/blender/depsgraph/intern/eval/deg_eval.cc:127
- 22	  handle_local_queue [inlined] at source/blender/blenlib/intern/task.c:420
- 23	  BLI_task_pool_work_and_wait at source/blender/blenlib/intern/task.c:944
- 24	  DEG::deg_evaluate_on_refresh(DEG::Depsgraph*) at source/blender/depsgraph/intern/eval/deg_eval.cc:406
- 25	  ::DEG_evaluate_on_framechange(Main *, Depsgraph *, float) at source/blender/depsgraph/intern/depsgraph_eval.cc:83
- 26	  BKE_scene_graph_update_for_newframe at source/blender/blenkernel/intern/scene.c:1388
- 27	  ED_update_for_newframe at source/blender/editors/screen/screen_edit.c:1568
- 28	  fluid_bake_sequence at source/blender/editors/physics/physics_fluid.c:307
- 29	  fluid_bake_startjob at source/blender/editors/physics/physics_fluid.c:446
- 30	  do_job_thread at source/blender/windowmanager/intern/wm_jobs.c:396
- 31	  tslot_thread_start at source/blender/blenlib/intern/threads.c:260
It crashes while baking ```lines=6 Blender[33943:176066] [AudioHAL_Client] HALC_ProxyIOContext.cpp:1399:IOWorkLoop: HALC_ProxyIOContext::IOWorkLoop: failed to send the final message to the server, Error: 0x10000003 (lldb) - 0 bb_combineMaps at source/blender/blenkernel/intern/fluid.c:792 - 1 update_obstacles at source/blender/blenkernel/intern/fluid.c:1301 - 2 manta_step at source/blender/blenkernel/intern/fluid.c:3590 - 3 BKE_fluid_modifier_processDomain at source/blender/blenkernel/intern/fluid.c:4002 - 4 BKE_fluid_modifier_process at source/blender/blenkernel/intern/fluid.c:4034 - 5 BKE_fluid_modifier_do at source/blender/blenkernel/intern/fluid.c:4046 - 6 applyModifier at source/blender/modifiers/intern/MOD_fluid.c:119 - 7 modwrap_applyModifier at source/blender/blenkernel/intern/modifier.c:960 - 8 mesh_calc_modifiers at source/blender/blenkernel/intern/DerivedMesh.c:1179 - 9 mesh_build_data at source/blender/blenkernel/intern/DerivedMesh.c:1767 - 10 makeDerivedMesh at source/blender/blenkernel/intern/DerivedMesh.c:1900 - 11 BKE_object_handle_data_update at source/blender/blenkernel/intern/object_update.c:193 - 12 BKE_object_eval_uber_data at source/blender/blenkernel/intern/object_update.c:385 - 13 decltype(std::__1::forward<void (*&)(Depsgraph*, Scene*, Object*)>(fp)(std::__1::forward<Depsgraph*>(fp0), std::__1::forward<Scene*&>(fp0), std::__1::forward<Object*&>(fp0))) std::__1::__invoke<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339 - 14 std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__apply_functor<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, 0ul, 1ul, 2ul, std::__1::tuple<Depsgraph*&&> >(void (*&)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>&, std::__1::__tuple_indices<0ul, 1ul, 2ul>, std::__1::tuple<Depsgraph*&&>&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2216 - 15 std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>::operator()<Depsgraph*>(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2249 - 16 decltype(std::__1::forward<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&>(fp)(std::__1::forward<Depsgraph*>(fp0))) std::__1::__invoke<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339 - 17 void std::__1::__invoke_void_return_wrapper<void>::__call<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__functional_base:349 - 18 std::__1::__function::__func<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>, std::__1::allocator<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&> >, void (Depsgraph*)>::operator()(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1562 - 19 std::__1::function<void (Depsgraph*)>::operator()(Depsgraph*) const at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1913 - 20 DEG::(anonymous namespace)::evaluate_node(DEG::(anonymous namespace)::DepsgraphEvalState const*, DEG::OperationNode*) at source/blender/depsgraph/intern/eval/deg_eval.cc:116 - 21 DEG::(anonymous namespace)::deg_task_run_func(TaskPool*, void*, int) at source/blender/depsgraph/intern/eval/deg_eval.cc:127 - 22 handle_local_queue [inlined] at source/blender/blenlib/intern/task.c:420 - 23 BLI_task_pool_work_and_wait at source/blender/blenlib/intern/task.c:944 - 24 DEG::deg_evaluate_on_refresh(DEG::Depsgraph*) at source/blender/depsgraph/intern/eval/deg_eval.cc:406 - 25 ::DEG_evaluate_on_framechange(Main *, Depsgraph *, float) at source/blender/depsgraph/intern/depsgraph_eval.cc:83 - 26 BKE_scene_graph_update_for_newframe at source/blender/blenkernel/intern/scene.c:1388 - 27 ED_update_for_newframe at source/blender/editors/screen/screen_edit.c:1568 - 28 fluid_bake_sequence at source/blender/editors/physics/physics_fluid.c:307 - 29 fluid_bake_startjob at source/blender/editors/physics/physics_fluid.c:446 - 30 do_job_thread at source/blender/windowmanager/intern/wm_jobs.c:396 - 31 tslot_thread_start at source/blender/blenlib/intern/threads.c:260 ```
This issue was referenced by 5ce41e6f57
This issue was referenced by 5ce41e6f5706d4396c518be6e71e299ef95936ac
Member
Jacques Lucke self-assigned this 2020-03-27 12:33:59 +01:00
Reference: blender/blender#75111
