Select Linked works incorrectly #75128
Reference: blender/blender#75128
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash:
77d23b0bd7
https://youtu.be/ptnwfjPIuP0
The operator "Select Linked" does not select anything if one vertex is initially selected on the edge of a non-manifold object
test_select_linked.blend
Added subscriber: @ivpe
Added subscriber: @mano-wii
Can you provide a simple blend file showing the problem?
Strange, but I found out that the problem is related to the addon that I wrote. I’m trying to recreate the conditions that cause this behavior of standard tools, but I’m sure that the selection state does not contradict this
requirements. In the near future I hope to find the reason, I’ll ask you not to close the task yet.
I rewrote the part of the addon which causes further problems.
To recreate a problem you need to:
As you can see, problems arise only for the vertices located on the edge of the mesh, for the rest everything works fine
https://youtu.be/D1gunINN9PE
As much as I click on the mesh with the operator running, I can't reproduce the problem.
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
I've already tried to install 2.82a and to use daily build and I have the same issue. I made simplified as much as possible script. Please try to follow these steps:
Added subscriber: @ideasman42
At first I thought you were referring to the
select_linked_pick
operator (shortcut L).The
select_linked
operator (Ctrl L) actually ignores border elements if the delimitation is of theNORMAL
type.This seems to be buggy from the user's perspective.
I have not found documentation explaining this behavior. @ideasman42, does it work as intended?
I will consider this a bug for now.
This issue was referenced by
cdbb61704d
