Cast Modifier crashes upon entering Edit Mode #75156
Closed
opened 2020-03-28 12:01:17 +01:00 by Henrik D. · 10 comments
Member
Operating system: Linux (Debian bullseye)
Graphics card: Nvidia Geforce GTX 1070
Broken: from 82c51d0edb up to current master 2.83.11
Worked: before 82c51d0edb
If the cast modifier uses the geometry of a generate modifier it will cause a crash upon entering edit mode with edit mode visibility turned on
  1. add a screw modifier to the default cube
  2. add a cast modifier to the default cube
  3. make the cast modifier active in edit mode
  4. enter edit mode
**System Information** Operating system: Linux (Debian bullseye) Graphics card: Nvidia Geforce GTX 1070 **Blender Version** Broken: from 82c51d0edba up to current master 2.83.11 Worked: before 82c51d0edba **Short description of error** If the cast modifier uses the geometry of a generate modifier it will cause a crash upon entering edit mode with edit mode visibility turned on **Exact steps for others to reproduce the error** 1. add a screw modifier to the default cube 2. add a cast modifier to the default cube 3. make the cast modifier active in edit mode 4. enter edit mode
Author
Member
Added subscriber: @HDMaster84
Campbell Barton was assigned by Henrik D. 2020-03-28 12:01:54 +01:00
Author
Member
Added subscriber: @ideasman42
Member
Added subscriber: @brecht
Please ensure the bug is fully triaged when setting it to confirmed.
Member
Added subscriber: @ankitm
Member
- 0	 BKE_id_free_ex at blender/source/blender/blenkernel/intern/lib_id_delete.c:162
- 1	 BKE_id_free at blender/source/blender/blenkernel/intern/lib_id_delete.c:251
- 2	 deformVertsEM at blender/source/blender/modifiers/intern/MOD_cast.c:517
- 3	 modwrap_deformVertsEM at blender/source/blender/blenkernel/intern/modifier.c:991
- 4	 editbmesh_calc_modifiers at blender/source/blender/blenkernel/intern/DerivedMesh.c:1553
- 5	 editbmesh_build_data at blender/source/blender/blenkernel/intern/DerivedMesh.c:1825
- 6	 makeDerivedMesh at blender/source/blender/blenkernel/intern/DerivedMesh.c:1897
- 7	 BKE_object_handle_data_update at blender/source/blender/blenkernel/intern/object_update.c:190
- 8	 BKE_object_eval_uber_data at blender/source/blender/blenkernel/intern/object_update.c:385
- 9	 decltype(std::__1::forward<void (*&)(Depsgraph*, Scene*, Object*)>(fp)(std::__1::forward<Depsgraph*>(fp0), std::__1::forward<Scene*&>(fp0), std::__1::forward<Object*&>(fp0))) std::__1::__invoke<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339
- 10	 std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__apply_functor<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, 0ul, 1ul, 2ul, std::__1::tuple<Depsgraph*&&> >(void (*&)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>&, std::__1::__tuple_indices<0ul, 1ul, 2ul>, std::__1::tuple<Depsgraph*&&>&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2216
- 11	 std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>::operator()<Depsgraph*>(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2249
- 12	 decltype(std::__1::forward<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&>(fp)(std::__1::forward<Depsgraph*>(fp0))) std::__1::__invoke<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339
- 13	 void std::__1::__invoke_void_return_wrapper<void>::__call<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__functional_base:349
- 14	 std::__1::__function::__func<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>, std::__1::allocator<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&> >, void (Depsgraph*)>::operator()(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1562
- 15	 std::__1::function<void (Depsgraph*)>::operator()(Depsgraph*) const at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1913
- 16	 DEG::(anonymous namespace)::evaluate_node(DEG::(anonymous namespace)::DepsgraphEvalState const*, DEG::OperationNode*) at blender/source/blender/depsgraph/intern/eval/deg_eval.cc:116
- 17	 DEG::(anonymous namespace)::deg_task_run_func(TaskPool*, void*, int) at blender/source/blender/depsgraph/intern/eval/deg_eval.cc:127
- 18	 handle_local_queue [inlined] at blender/source/blender/blenlib/intern/task.c:420
- 19	 BLI_task_pool_work_and_wait at blender/source/blender/blenlib/intern/task.c:944
- 20	 DEG::deg_evaluate_on_refresh(DEG::Depsgraph*) at blender/source/blender/depsgraph/intern/eval/deg_eval.cc:406
- 21	 ::DEG_evaluate_on_refresh(Main *, Depsgraph *) at blender/source/blender/depsgraph/intern/depsgraph_eval.cc:64
- 22	 scene_graph_update_tagged at blender/source/blender/blenkernel/intern/scene.c:1314
- 23	 BKE_scene_graph_update_tagged at blender/source/blender/blenkernel/intern/scene.c:1353
- 24	 wm_event_do_depsgraph at blender/source/blender/windowmanager/intern/wm_event_system.c:359
- 25	 wm_event_do_refresh_wm_and_depsgraph at blender/source/blender/windowmanager/intern/wm_event_system.c:385
- 26	 wm_event_do_notifiers at blender/source/blender/windowmanager/intern/wm_event_system.c:550
- 27	 WM_main at blender/source/blender/windowmanager/intern/wm.c:450
#28	 main at blender/source/creator/creator.c:524
```lines=8 - 0 BKE_id_free_ex at blender/source/blender/blenkernel/intern/lib_id_delete.c:162 - 1 BKE_id_free at blender/source/blender/blenkernel/intern/lib_id_delete.c:251 - 2 deformVertsEM at blender/source/blender/modifiers/intern/MOD_cast.c:517 - 3 modwrap_deformVertsEM at blender/source/blender/blenkernel/intern/modifier.c:991 - 4 editbmesh_calc_modifiers at blender/source/blender/blenkernel/intern/DerivedMesh.c:1553 - 5 editbmesh_build_data at blender/source/blender/blenkernel/intern/DerivedMesh.c:1825 - 6 makeDerivedMesh at blender/source/blender/blenkernel/intern/DerivedMesh.c:1897 - 7 BKE_object_handle_data_update at blender/source/blender/blenkernel/intern/object_update.c:190 - 8 BKE_object_eval_uber_data at blender/source/blender/blenkernel/intern/object_update.c:385 - 9 decltype(std::__1::forward<void (*&)(Depsgraph*, Scene*, Object*)>(fp)(std::__1::forward<Depsgraph*>(fp0), std::__1::forward<Scene*&>(fp0), std::__1::forward<Object*&>(fp0))) std::__1::__invoke<void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*, Scene*&, Object*&>(void (*&)(Depsgraph*, Scene*, Object*), Depsgraph*&&, Scene*&, Object*&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339 - 10 std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__apply_functor<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, 0ul, 1ul, 2ul, std::__1::tuple<Depsgraph*&&> >(void (*&)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>&, std::__1::__tuple_indices<0ul, 1ul, 2ul>, std::__1::tuple<Depsgraph*&&>&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2216 - 11 std::__1::__bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&>, __is_valid_bind_return<void (*)(Depsgraph*, Scene*, Object*), std::__1::tuple<std::__1::placeholders::__ph<1>, Scene*, Object*>, std::__1::tuple<Depsgraph*&&> >::value>::type std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>::operator()<Depsgraph*>(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:2249 - 12 decltype(std::__1::forward<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&>(fp)(std::__1::forward<Depsgraph*>(fp0))) std::__1::__invoke<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/type_traits:4339 - 13 void std::__1::__invoke_void_return_wrapper<void>::__call<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*>(std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>&, Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__functional_base:349 - 14 std::__1::__function::__func<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&>, std::__1::allocator<std::__1::__bind<void (&)(Depsgraph*, Scene*, Object*), std::__1::placeholders::__ph<1> const&, Scene*&, Object*&> >, void (Depsgraph*)>::operator()(Depsgraph*&&) at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1562 - 15 std::__1::function<void (Depsgraph*)>::operator()(Depsgraph*) const at /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/functional:1913 - 16 DEG::(anonymous namespace)::evaluate_node(DEG::(anonymous namespace)::DepsgraphEvalState const*, DEG::OperationNode*) at blender/source/blender/depsgraph/intern/eval/deg_eval.cc:116 - 17 DEG::(anonymous namespace)::deg_task_run_func(TaskPool*, void*, int) at blender/source/blender/depsgraph/intern/eval/deg_eval.cc:127 - 18 handle_local_queue [inlined] at blender/source/blender/blenlib/intern/task.c:420 - 19 BLI_task_pool_work_and_wait at blender/source/blender/blenlib/intern/task.c:944 - 20 DEG::deg_evaluate_on_refresh(DEG::Depsgraph*) at blender/source/blender/depsgraph/intern/eval/deg_eval.cc:406 - 21 ::DEG_evaluate_on_refresh(Main *, Depsgraph *) at blender/source/blender/depsgraph/intern/depsgraph_eval.cc:64 - 22 scene_graph_update_tagged at blender/source/blender/blenkernel/intern/scene.c:1314 - 23 BKE_scene_graph_update_tagged at blender/source/blender/blenkernel/intern/scene.c:1353 - 24 wm_event_do_depsgraph at blender/source/blender/windowmanager/intern/wm_event_system.c:359 - 25 wm_event_do_refresh_wm_and_depsgraph at blender/source/blender/windowmanager/intern/wm_event_system.c:385 - 26 wm_event_do_notifiers at blender/source/blender/windowmanager/intern/wm_event_system.c:550 - 27 WM_main at blender/source/blender/windowmanager/intern/wm.c:450 #28 main at blender/source/creator/creator.c:524 ```
Member
Was cleaning up the trace.
This issue was referenced by ac02c702e5
This issue was referenced by ac02c702e5ecfd1a01f0c377dc30336a473580ca
5 Participants
Reference: blender/blender#75156
