BLI_assert failed when deleting object in debug build (only) #75279
7 Participants
Reference: blender/blender#75279
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Graphics 6100 Intel Inc. 4.1 INTEL-14.4.23
Broken: version: 2.83 (sub 11) Debug build, branch: master, commit date: 01-04-2020, hash:
rBUnknown
Worked: Release build works fine.
See attached blend file.
test (1).blend
Added subscriber: @monique
Added subscriber: @lichtwerk
Can confirm.
Added subscriber: @iss
Changed status from 'Confirmed' to: 'Needs User Info'
can you clarify hash to test with? Can not reproduce with
25b2b6724d19
I am getting this on
25b2b6724d
.System Information
Operating system: Linux-5.5.8-200.fc31.x86_64-x86_64-with-fedora-31-Thirty_One 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.64
Broken: version: 2.83 (sub 11), branch: master, commit date: 2020-04-01 14:21, hash:
25b2b6724d
Added subscriber: @ankitm
lite also works fine.
v2.82a has this issue too.
Added subscriber: @mont29
I think the problem is rather with ID management code (remapping ID pointers to NULL here) not properly tagging IDs for updates... Investigating.
Added subscriber: @Sergey
Hrmm, in fact ID deletion code itself seems to be fine, issue only happens with Object deletion operator (from 3DView), since deleted object is used by a custom property it is not actually deleted, just removed from any collection.
@Sergey I could use your expertise on depsgraph/CoW here (crash is actually a use-after-free memory on CoW object, see ASAN bactrace below).
Question is, could CoW system be somehow 'broken' in case where an object is not in any collection (hence not in any ViewLayer of any scene), but is still present in Main and referenced by some other data-blocks (through custom properties here)?
From that backtrace my (uneducated) guess would be that CoW frees the object copy not in any scene anymore, even though that object remain accessible through other CoWs IDProperties.
All the referenced IDs are to be explicitly pulled into the dependency graph, otherwise you are ruining integrity of the scene.
As an example see usage of
modifiers_foreachIDLink
indeg_builder_nodes.cc
anddeg_builder_relations.cc
. Quick fix would be to do similar thing for ID properties.However, this is actually an open topic of what to do with IDs referenced from ID properties. It might be wasteful to just pull all the referenced IDs, but it could be fragile if we don't do it.
So the way to go would be to add something similar
build_animdata()
(build_idproperties()
?), to be called by all builders (nodes and relations) for all IDProps cases? Including those from bones/poses, nodes, and sequencer...The other solution would be to completely ignore those IDProps ID pointers, and add a parameter to libquery to skip those, so that depsgraph can fully ignore them? But that would likely cause issues in any code dealing with CoW datablocks I guess...
Yep. Sounds about right. Baiscally somethinng like
This is plausible solution as well. Isn't great from integrity point of view, but better from ease/performance/memory points of view.
What are the IDs in ID properties are used for? Is there any common usage?
I have no typical usecase in mind, afaik those are mostly used by thirdparty tools/addons… They should never be used by core code itself, and they cannot be directly defined by users, so they should almost never be required within depsgraph context. But... they can be used by e.g. advanced python drivers or other fancy features, so I don’t think we can rule them out of evaluation completely? Though maybe that is not actually a valid argument, my knowledge of current driver evaluation process is rather rusty.
Added subscriber: @dr.sybren
Then how about we take the consistency approach and pull IDs from custom properties into the graph?
If you can point or provide some function to iterate via IDs used by IDProperties them me or @dr.sybren can easily do depsgraph changes.
This issue was referenced by
37e08e526c
Well, this is easy enough that I can at least propose a patch ;)
