Unexpected output from Musgrave Texture #75774
5 Participants
Reference: blender/blender#75774
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.74
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-04-15 15:46, hash:
4dc534aa04
I suspect that the Fac output from the Musgrave Texture Node is outputting values less than zero. This produces unexpected results when running its output through any number of mathematical operations.
I don't know how to debug this further since we can't see the actual numerical output from any of these nodes.
What straight black produces:
What, uh, less than black produces:
Material 000.blend
Added subscriber: @Russ1642
Added subscriber: @mano-wii
I can confirm that there are values less than 0 (just use the match node with Less Than mode).
Although it does not seem conventional, this is not a bug and has been working since this node was implemented.
Fac inputs and outputs are supposed to be limited to the range of 0 to 1. It's not 'unconventional', it breaks the workflow because it's completely unexpected. We're making assumptions about what our math will do based on the number not dropping below 0.
Tell us this please: What range of numbers does that node output? -1 to 1? -10000 to 1? -1 to 20000? We now have no idea. Are other Fac outputs not limited to the range of 0 to 1? What is the range we're supposed to expect. Seeing as Blender is moving towards a "nodes for EVERYTHING" design I'd think this is something that ought to be ironed out now.
Changed status from 'Archived' to: 'Needs Triage'
Added subscriber: @brecht
Ideally these would be in the range 0..1 and we may work on that in the future. But changing this is outside the scope of the bug tracker.
https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
We can't do proper math using the output from the Musgrave Texture node. For example, when you multiply two numbers together and the lowest value you're expecting is a zero, a negative number really messes things up. Which would be perfectly fine if the software wasn't LYING to you by telling you that the numbers were strictly in the 0 to 1 range. That's what "Fac" output means. That's its purpose.
Added subscriber: @EAW
Thank you for the report. You are correct. The range of the Musgrave node when set to fBM is [-1,1]. Kenton Musgrave wrote
The example in the manual shows the use of a map range node to normalize the [-1,1] range to [0,1] if that is the look you are going for.
That being said, I think you are confusing this with another issue. The reason you aren't seeing a "true black" in your 1st and 3rd images is because you are using the principled shader. The surface is reflecting the surrounding light. If you use an emission shader, or if you set the specular slider to 0, you will get results that match picture 2 and 4.
The issue I have isn't the range of the Musgrave Node or the shader. It's really the labelling of the Fac output. We're led to believe that ALL Fac outputs have a range of 0 to 1. Blender is moving towards having more and more nodes. If this assumption isn't correct then it should be addressed. I think it's a bad idea to have a hundred Fac outputs limited to 0-1 and then suddenly this one node is different. I was trying to do some math with the output of the node and was scratching my head trying to figure out what wasn't working. So the bug is that the output from the node is labelled Fac. Call it something else if it doesn't behave like every other Fac. Thank you.
Note: there were no other responses when I started researching and writing my above response. =)
You also have to remember why Kenton Musgrave created these noises in the first place: to create realistic procedural generated synthetic terrain models. The places where the output is less than zero are lakes.
Edit: Better render of my example
This has NOTHING to do with the Musgrave Texture node in particular. Either Fac outputs are supposed to be in the 0 to 1 range or they're not. Blender nodes have been designed to have a common interface and that was one of the decisions. So if you want to keep the range -1 to 1 then at least call it something other than a Fac output so it's not so damn confusing. If every Fac output had a different range it'd be a mess. This is about consistency and predictability.
Again, I wrote my above comment before seeing your comment. It was an effort to describe why the range is what it is, and not intended to dismiss your point.
I can get behind the output being changed from
Fac
toValue
. But as Brecht said, that is outside the scoop of the bug tracker.Changing the range might be outside the scope of the bug tracker, especially since it'll break existing materials. However, the label is most certainly a bug and is easy to change.
This issue was referenced by
c87dd76937
Changed status from 'Archived' to: 'Resolved'
Thank you. :)
