Liquid simulation, cache type "Replay", doesn't recognize objects created after Domain creation, doesn't update #75850
Reference: blender/blender#75850
Operating system: Ubuntu 18.04
Graphics card: irrelevant
Broken: 2.83 Beta
8cb10c124e
17 Apr 2020Short description of error
Under cache type "Replay" (which appears to be the new default) the domain only takes into account fluid objects that were created before creating the domain!
Creating domain first: Doesn't work
Creating flow/effectors first: Kind of works
However in this situation I can't make use of the "Replay" advantages because any change I make to the scene won't be taken into account (unless I change cache location)
Added subscriber: @NicolaSap
Added subscriber: @ankitm
I can see the particles, & I followed the steps in order. I'm using
221a7002a9
Please share a blend file for both cases.
I don't have my building environment ready, so I downloaded last night's builds (
76b3aac802
). I still reproduce the error.However, if I save and reopen, the particles now show correctly (but the cache is empty). This is an interesting finding, by the way. However, it means that I can't share a file to demonstrate, because opening from file is effectively a workaround.
I'll show a video instead:
Peek 2020-04-18 19-15.mp4
PS: saving alone doesn't help, nor does saving at the very beginning (which would be a problem if cache was somewhere in
, which it isn't). I have to save then re-open to obtain a workaroundPlease try after moving the blender preferences folder outside so that blender starts fresh & you have your preferences safe.
I used
1f1520a045
.Still cannot redo. Making the inner cube flow | liquid shows particles.
Screen Recording 2020-04-19 at 11.47.54.mov
I've repeated with fresh preferences and still no luck :(
Added subscriber: @iss
@NicolaSap does this happen if you modify domain content and press shift + right key?
It seems that if you move playhead my mouse, domain won't update
Added subscriber: @mano-wii
I can confirm that there is some strange behavior.
Although there are workarounds (for example updating the cache) this should not happen.
So I am confirming it as a bug.
The issue I was encountering seems to be fixed in the latest builds (
d712f1f83a
)What is still true, however, is that there isn't a way to invalidate a "Replay" cache once the simulation has started. If I cache the first 3 frames, then I add/remove/move some element, playing the animation still works using the original flows and effectors. In the other simulation engines that allow "Replay" modes (e.g. rigid body, cloth) going back to frame 0 and re-starting the animation would invalidate and recompute the cache, if something has changed in the meanwhile.
I don't know if this (↑) is the "strange behavior" Germano is talking about. If it is, then this Task should probably stay open. If it's not, then probably this Task can be closed and my other concern can be ticketed separately (can/should I do it or is it considered a feature request?)
As @iss also said above, shift right or going to the starting frame updates the cache.
If there's isn't anything else @mano-wii you noticed, closing it should be fine.
This is not true for me!
Peek 2020-04-25 12-24.mp4
This neither
Peek 2020-04-25 12-25.mp4
d712f1f83a
builds from yesterday)Does the effector have some thickness ?
Yes, it's a scaled cube. It doesn't have "Surface thickness" but that's not required. Indeed, it works just fine if I manually delete the cache and restart
But Blender won't invalidate the cache on its own. The problem is with the cache, not with my scene settings.
It's been pointed out, in the chat, that the shift in focus of this Task may be confusing.
Since the issue that gives the title to this Task is now solved, this task can be closed as Resolved.
I've opened another Task (#76095) for the bugs that emerged after the original bug.
