Cycles Optix rendering slows down on second tile #75955
5 Participants
Reference: blender/blender#75955
Operating system:Windows 10
Graphics card: 1x Nvidia RTX 2080 Ti
Broken: Blender 2.82a
Worked: every previous version
When I render on Optix sometimes (50% times) rendering goes extremely slow after rendering the first tile of render
This is happening to me only on hudge scenes like 1,44GB. And this is not happening every time but quite often ( 50% of times )
To Explain that let's just assume that we have an interior scene which has nothing special in it ( I know that optix is not working with AO shader and branched path tracing)
and expected time of rendering goes from 1 hour up to 15 hours or even 20 hours
I know that you might say that not every tile is rendering with the same speed but that is not an issue. When I restart PC or sometimes when I restart blender or sometimes when I prerender scene for something like 1 minute with material override option enabled render goes in the correct way. What I mean by that is that:
As I wrote before this happens to me only on complicated hudge scenes but my work consits only those type of scenes ( I'm interior designer)
I have this problem since the first release of blender with optix rendering. I,ve also checked tenperatures on my GPU and nothing goes above 66 degrees.
Here is my file but it is quite large 1,44 GB:
poznań restauracja zmiany evee zmiany ewa textury small.blend
For me it is hude deal if my render goes 1 hour or 15 hours so pls help me :)
Added subscriber: @sohoha
#75954 was marked as duplicate of this issue
Added subscribers: @pmoursnv, @brecht
Can you run
blender_debug_log.cmd
included with Blender, do the render, and attach the resulting logs here? This will include more detailed info about what Cycles is doing.Does this happen when rendering with CUDA instead of Optix?
Maybe it's running out of GPU memory somewhere and then falling back to slower CPU memory.
Rendering on cuda sometimes also crashes but this is less often than on Optix
Here is debug log:
blender_debug_output.txt
blender_system_info.txt
I've also found out that doing prerender with material override option enabled with simple principled BSDF helps 100% of times. But I have no idea what is causing that behaviour.
This is probably the issue:
In general
__texture_info
andRenderBuffers
should not be allocated in host memory because it's too slow. Instead moving more__tex_image
to the host should be preferred.Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Problem is still ongoing. I've made two render logs. One is correct with remaining render time around 1h. Second one is with crash I've described above and it's remaining time is around 150 hours. All settings are the same except for number of objets in the scene which for Right render scen is smaller. I know that you may say that crash ocurs according to number of objects in the scene however it is not that simple because Sometimes it can crash on one scene and next time it may go perfectly smoth with next render
blender right optix render.rar
blender wrong optix render.rar
Here is the scene
poznań restauracja zmiany evee zmiany ewa8 textury small temp to render3.blend
Added subscriber: @iss
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
@sohoha I am looking at older reports, According to comments in D7426 this should be resolved already. Can you confirm this?
Added subscriber: @lichtwerk
