Crash with 'Split Edges and Faces' | Auto-Merge #75994
Closed
opened 2020-04-22 10:58:36 +02:00 by irex124 · 5 comments
Contributor
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-04-15 22:31, hash: 32cd853294
Crash when trying to extrude if "Split edges and faces" is turned on in auto-merge setting.
Auto-merge crash.blend
Open the following file, select everything and then extrude. Blender should crash when you confirm the extrusion.
blender_debug_output.txt
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87 **Blender Version** Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-04-15 22:31, hash: `32cd853294` Worked: (newest version of Blender that worked as expected) **Short description of error** Crash when trying to extrude if "Split edges and faces" is turned on in auto-merge setting. **Exact steps for others to reproduce the error** [Auto-merge crash.blend](https://archive.blender.org/developer/F8488909/Auto-merge_crash.blend) Open the following file, select everything and then extrude. Blender should crash when you confirm the extrusion. [blender_debug_output.txt](https://archive.blender.org/developer/F8488914/blender_debug_output.txt)
Author
Contributor
Added subscriber: @Pasang
Germano Cavalcante self-assigned this 2020-04-22 15:13:27 +02:00
This issue was referenced by f9649e2bf1
This issue was referenced by f9649e2bf1848d44ddf8739dd3ef6e087f291f28
This issue was referenced by f5b540593c
This issue was referenced by f5b540593cd599cf47ad6763b87033c6c0964d87
Thomas Dinges added this to the 2.83 LTS milestone 2023-02-08 16:38:05 +01:00
Reference: blender/blender#75994
