Operation "Remove from All Unlinked Collections" removes selected objects from all collections #76014
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#76014
System Information:
Operating system: NA
Graphics card: NA
Blender Version:
Broken: Blender 2.83 a68bd94d110a
Worked: Unsure
Short description of error:
Using the keyboard shortcut "Shift-Ctrl-Alt-G" or the drop down menu "Object>Collections>Remove from All Unlinked Collections" in the 3D viewport seems to remove the selected objects from all collections, not just the unlinked ones as the action suggests.
I am asking is this a bug or working as intended as part of efforts in completing #75511.
Added subscriber: @Alaska
Added subscriber: @lichtwerk
Confirmed, checking...
This issue was referenced by blender/blender@0fbcb824d0
@lichtwerk. Thanks for updating that for me. I will check it out once a daily build for that patch is out then I will make the changes to the documentation.
Documentation updated in rBM6561
